Fastpatch/Dashpatch Came Out Uneven...need Suggestions? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2009, 08:11 AM   #1
Fastpatch/Dashpatch came out uneven...need suggestions?
I plan to lay some vct in a small room (~100sq ft). I removed some badly cracked vct and did an entire coat of fastpatch to even out the floor. Bad thing is, it didnt come out even.
Should I plan on sanding the floor to even it out, or pray that the glue will even out the floor on its own?
ocz800 is offline   Reply With Quote
Old 05-14-2009, 03:31 PM   #2
Rewards Points: 150
Is that a gypsum based patch? if so take a hammer and smash it out.
Use a portland based leveler or feather finish
mike costello is offline   Reply With Quote
Old 05-14-2009, 09:16 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
VCT adhesive isn't going to fill anything or make any corrections. In fact, if you get it too thick your life as you know it will be over.
I'm not familiar with Dash Patch but unless you know what you are doing you stand little chance of flattening that floor with just any cheap patching compound and a trowel. As Mike has said; the materiel needs to be a Portland based compound.
Better yet...use Self Levelling Compound.
uneven wood paneling joefromcal Carpentry 6 04-30-2009 09:50 PM
Uneven Studs and mounting a Flat Screen -Please Help! SassyLilRedhead Home Theater 6 01-22-2009 09:33 PM
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 03:20 PM
