Fastening Cement Backer Board - Flooring - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 08:19 PM   #1
Fastening Cement Backer board
Beside using a quick drive screw gun, What are some other brand screw guns (cheaper) that would fasten the backer board to the subfloor?
Stacyj is offline   Reply With Quote
Old 02-11-2011, 08:21 PM   #2
Rewards Points: 1,528
A variable speed electric drill could do it.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Stacyj (02-12-2011)
Old 02-11-2011, 09:28 PM   #3
woodman58's Avatar
Rigid from Home Depot has 2 screw guns that hold strips of screws. One is corded and the other is battery powered.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Stacyj (02-12-2011)
Old 02-12-2011, 12:25 AM   #4
Thanks you for that info
Old 02-12-2011, 12:26 AM   #5
Thank you for that info
Old 02-12-2011, 01:05 AM   #6
firehawkmph's Avatar
Rewards Points: 1,800
Stacy,
A cordless impact does a fine job. I put down a lot of cement board with one. You should use the screws made for installing cement board. They are usually on a display right next to the cement board. Don't forget your thinset.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-12-2011, 09:09 AM   #7
heavy duty cordless drill (18-24v), heavy duty cordless impact driver, roofing nailer
acglobal is offline   Reply With Quote
Old 02-12-2011, 02:46 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use cement board screws with the square-drive.
Don't forget all cement board on floors must be installed in a bed of fresh thinset, then screwed.
XXX
Old 02-12-2011, 08:59 PM   #9
1 1/4" galvanized roofing nails from a roofing nailer. Does not get any faster.
FlooringDude is offline   Reply With Quote
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 10:13 PM
Cement Board Install Vica Building & Construction 5 01-27-2011 08:24 PM
Laying cement board oguevarra Flooring 18 12-16-2009 10:21 AM
Cement Board Install Question AVTechMan Building & Construction 9 03-19-2009 03:45 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 02:30 PM
