Face Nailing Question.... - Flooring - DIY Chatroom Home Improvement Forum
Old 12-20-2007, 10:03 AM   #1
face nailing question....
Hi,
I am installing 3/4" maple strip flooring, and it is my first hardwood flooring project. I understand that the first row must be face nailed. I would like to use a pneumatic nailer, as opposed to setting each nail by hand. What type of nailer and what type of nail is recommended for this purpose? In addition to the size of the nail, is there a specific type of nail for this purpose? Thanks.
Shawn in Toronto
shawn99 is offline   Reply With Quote
Old 12-20-2007, 12:05 PM   #2
Oldguy
Rehabber's Avatar
Use the bostitch flooring nails and a PC fcn200 gun
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-20-2007, 03:58 PM   #3
Home Improvement Guy
ron schenker's Avatar
Shawn, your local Toronto HD rents Bostitch nailers and sells Bostitch nails. Use the 2" nails. You probably will have to brad nail(2" 18 guage) a couple of rows till you get far enough away from the wall to fit in the nailer. Face nail close to the wall so the 1/4 round will hide the nail. The next row can be brad nailed into the tongue at an angle. Many rental centres have Primatech floor nailers which are also very good. Set your compressor at around 100psi
ron schenker is offline   Reply With Quote
Old 12-20-2007, 09:33 PM   #4
Oldguy
Rehabber's Avatar
I find the 18 ga nails to be a little tight on holding power, I use the 16 ga flooring nails like the rest of the floor. You have a slightly larger hole to fill, but I would rather have the extra holding power. IMNTBHO
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 08:33 AM
