Old 11-30-2012, 12:39 PM   #1
Exterior Grout and Caulking Recommendations????
Hello All,
Can anyone recommend a good "exterior" tile caulk and matching or near matching colored grout? The owners picked out a Mapei Keracolor "Silver" color which is just a very light gray. I "prefer" a stain resistant grout and a long lasting caulk.
1) The grout lines are very small (1/16in) due to interlocking tiles (porcelain).
2) I broke the tile pattern into four 10ft x 10ft sections (slab=10ft x 40ft total); and seperated these sections with a 1/4in grout line. The caulking will go into these 1/4in joints, for expansion purposes, in addition to the perimeters.
3) Laticrete Latasil caulking reads very good for this application but the local distributor only has 4 tubes....
Thanks,
Ralph
Ralph III is offline   Reply With Quote
Old 11-30-2012, 04:46 PM   #2
Tileguy
JazMan's Avatar
Ralph,
It's usually best to keep all Q's in one thread, but I understand why you started a new one in this case, no problem.
You're using Mapei Silver, (hopefully sanded), most people would select Mapei caulk too. But, Mapei caulk does not meet ASTM C920 specs for this purpose.
Laticrete's Latasil is good stuff and there should be a color that is very close. Being 100% silicone may make it harder to work with for many people, but if you're comfy, OK. The slight difference in color may not be noticeable, considering that grout/caulk within the same brand vary in color anyway.
Latasil meets ASTN C920 for many uses, only does not meet "Use T" which is for use in joints subjected to pedestrian and vehicle traffic. (Did I mention Laticrete makes great grouts too?). But since the joints will be (supposed to be), 3/8-1/2" and slightly below the surface it should be ok. It's better than nothing and can be redone easily if necessary.
Well, you know 1/4" is less than industry recommendations, but do as you like. Problem is that if this job goes bad in a couple of years the HO will do research and find ways to make you pay.
Need more? No problem.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 12-01-2012, 10:00 AM   #3
Doer of Many Things
poppameth's Avatar
Mapei makes Opticolor, an epoxy stain resistant grout just like Spectralock. If they are dead set on that color then Opticolor is an option. Also Mapei also has their own version of Latisil now. It's called Mapeisil. It's probably special order though.
poppameth is offline   Reply With Quote
Exterior Window Caulking Amitabh Windows and Doors 7 11-13-2012 11:37 AM
Bathroom floor/tub and caulking soulstar General Discussion 5 11-10-2011 11:49 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 06:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
