Exposing Old Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 02:27 AM   #1
Rewards Points: 39
exposing old hardwood floors
i want to rip up my carpet and just have the bare hardwood floors. tired of the carpeted look. the wood is oak, or at least the wood in the living room is. a test section i did some time ago looks fine--not perfect, but better than the hideous carpet.
is this as simple as removing the carpet and wiping off any residue from glues etc.? or am I going to have to sand and refinish the floor, even if it was already finished at one point in its life (carpet is, I'd estimate, 15 years old; house 1950s)? the latter isn't something i want to do right now. i of course have no idea what's under the carpet (presumably the carpet was laid for a reason), but i'm more wondering if, regardless of the floor's condition, i have to redo the floors. if that's the case, this idea gets shoved away until i have time to do it properly.
bugmenot is offline   Reply With Quote
Old 06-22-2012, 08:57 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
It really depends on if it was glued down or not. If it was, you have to scrape as much glue off, then sand. We got lucky with our wood floors, and only had tack strips holding the carpet down, with the floors in amazing shape. No work needed with ours, other than tearing up the old carpeting and pulling the strips.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-22-2012, 10:48 AM   #3
I would be willing to guess that your beautiful hardwood floors under your carpet, have pad and tack strip. Removing the carpet is easy and the strip. Just get colored wood filler and your good to go. If you want a new look, solid old school floors can be sanded and finished. Made to look brand new. You will also need to install new quarter rounds on top of the wood after carpet removal. Sounds like fun. Good luck.
Thefloorman is offline   Reply With Quote
Old Glue on Original Hardwood Floors! gh4444 Flooring 5 02-11-2012 01:13 PM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Easy maintanence and child friendly Hardwood floors? gante Flooring 2 03-11-2008 09:04 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
