Exposed Black Mastic Patches - Flooring - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 08:26 AM   #1
exposed black mastic patches
In prepping my basement floor for tile, I started tearing out the carpet and found spots of black mastic patches stuck to the concrete pad. I had them tested to contain 4% asbestos. So my question is, are these patches of black mastic in themselves dangerous? Or only if I start sanding or breaking them apart? I feel like I should just leave them alone and go right over them, but they are exposed at the moment so I'm a bit worried about them.
rakuz66 is offline   Reply With Quote
Old 09-20-2010, 10:32 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Not a tile guy, they will have to tell you if you can go over it. If you can leave it, thats what you should do. If you scrape it up, just keep it misted with water and wear a mask. It is not dangerous unless it becomes friable.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-20-2010, 10:45 AM   #3
Just sitting there won't harm anything. If you do anything with it just do like the above poster already said. Your bond to the floor is only as good as what you go over. If it is dried out or flaky the possibility of bond failure of your tile is increased. I personally would get rid of it.
JCW355 is offline   Reply With Quote
Asbestos Black Mastic Removal? Ken-SanDiego General DIY Discussions 3 12-30-2009 08:26 AM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Install hardwood over black mastic? SuperDoug Flooring 2 10-28-2007 12:52 PM
Paint/seal over black mastic KBO123 Flooring 1 12-06-2005 02:11 PM
