Expert Advice..Hardwood Floor Finished With Alcohol Based Product Followed By Oil Bas - Flooring - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 06:42 PM   #1
Unhappy
Expert advice..Hardwood floor finished with alcohol based product followed by oil bas
Hello.
I recently had brazillian cherry floors put in my home. The contractor said he used an alcohol based poly named synteko..similar to a gymnasium floor finish. Anyway, the floor finish had many streaks and he said it was b/c the product "dried too quickly" for the hallway. We had the floors finished 2 times and the same problem. 3rd try...this last time he said he would finish it correctly and it looks better but it still does not look right. I found a cap that said "miniwax high build polyurethane" and it is an oil based top coat.
Should he have used this oil based top coat finish on an alcohol based floor finish?
mtrusso is offline   Reply With Quote
Tags
hardwood floor finish
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
need advice of choosing the proper roofing shingle product nc_yella Roofing/Siding 10 11-19-2008 04:49 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
Advice on fixing scratches and chips in hardwood floor? bathroom nightmare Flooring 1 02-12-2008 11:08 PM
