Expansion Joints - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2006, 04:14 PM   #1
Expansion Joints
Hello :
I need some info on expansion joints in laminate flooring. I'm installating it in a basement over a concrete subfloor. The room is about 34 feet wide. The manufacturer states that I need an expansion joint if the run will be over 30'. For aestetic reasons, I'd like to avoid this. I'd prefer a continuous run without a break. I have carpeting in the room right now. I ripped up some of the carpeting and the 3/4" think baseboards are 7/16" above the flloor. I'm thinking of running the floor right under the baseboard - leaving 1/2" for expansion. Think this would allow for enough expansion to avoid the need for an expansion joint?
Thanks.
mpt1123@adelphia.net is offline   Reply With Quote
Old 03-06-2006, 05:02 PM   #2
Floorwizard's Avatar
what is the exact product you are using.
even with the 1/2 expansion, you will need to add a break if the room is over 30 feet. If that is indeed what the manufacturer states.
I know of some companies who have allowed Basketball courts to be done without a break.
no problems.
but that is with higher end lam.
Floorwizard is offline   Reply With Quote
Old 03-06-2006, 06:10 PM   #3
Thanks Florcraft.
The product is Mannington M-Lock.
Old 03-08-2006, 02:49 PM   #4
is that the high end total plastic stuff?
Old 03-09-2006, 05:44 AM   #5
I think so. It's called The NatureformŽ Plank Collection.
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 10:02 PM
Why do drywall joints crack in garages? Weelee929 General DIY Discussions 3 01-06-2006 07:30 AM
