Old 07-01-2009, 08:49 PM   #1
Default expansion gaps and doorways?
Hello, I'm going to have about 25 feet wide of hardwood flooring that is going to end at an exterior doorway. I know about leaving expansion gaps at the walls but how does this work at a doorway? Is there a space where the flooring can expand-it looks like the flooring will just but right up to the threshold and I am worried about this but maybe it is designed so the flooring can go under the threshold? House was built in 1993. many thanks as always
adjason is offline   Reply With Quote
Old 07-01-2009, 10:36 PM   #2
You need to leave an expansion space there as well. You should be able to put a piece of trim to match the flooring and secure it to the threshold on the door. I have also set the door on top and run the flooring underneath. Part of this depends on what the threshold looks like and whether you have an inswing or outswing.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-02-2009, 08:43 AM   #3
Which direction are you running your flooring? If it's running the length of the hall way, there is no reason to leave room for expansion. Wood does not expand over it's length, just it's width.
pinwheel45 is offline   Reply With Quote
Old 07-02-2009, 08:55 AM   #4
Although wood does not expand as much parallel to the grain and it does perpendicular to the grain it still expands this way too. You would also negate the ability of the wood to move perpendicularly if you did not allow a space on the end grain.
Old 07-02-2009, 08:59 AM   #5
I been installing floors since 95 & have been professionally working wood for over 25 years. Wood doesn't expand enough over it's length to worry about expansion.
More On This Topic
Victorian architecture became popular during the reign of England's Queen Victoria in the late 1800s to the early 1900s, but the period of Victorian architecture spans from 1825 to 1900. The most popular of these houses was the Queen Anne. Queen Anne... Read More »
Hi I am Betty Ingham, and I am speaking on behalf of Expert Village. The floor in this house have all been replaced because the floors were originally so beaten up and so patched that we really couldn't use them. So, we got the wood from a mill, and it... Read More »
Hardwood is a durable, low maintenance choice for flooring, but even the highest quality wood floors can end up with scratches, dents and dull finishes. Daily wear and tear is inevitable, but you can prolong the new look of your floors by taking a few... Read More »
Hi, this is Jon, and in this clip we'll be gluing the threshold. At the bottom of our door we have have our threshold, and before we install our door we need to put some construction adhesive underneath the threshold, and that's going to help hold that... Read More »
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality assurance walk through on this house. When you are looking at these doors, one of the biggest things you are going to want to look at on... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
