-   -   Etching Concrete Floor (http://www.diychatroom.com/f5/etching-concrete-floor-183155/)
pete0403 07-06-2013 03:38 PM
Hi,
I'm finishing a basement floor with "Hard Rock" epoxy. The room is a grooming shop and the epoxy floor will stand up to moisture and dog's nails etc for a long time.
I do have to etch the floor though as it is very smooth. I don't want to use chemical since it will be hard to rinse and there are finished walls in the room. What are my other options? Stiff wire brush? Nails through a piece of wood? Coarse sandpaper?
Any advice will be greatly appreciated.
RWolff 07-06-2013 04:36 PM
Originally Posted by pete0403 (Post 1212364)
Hi,
Well... you'd like to HOPE it does anyway, I'm not fan of epoxy paints and the like, epoxy is an adhesive, it's also brittle. I know years ago I used an epoxy paint on an old pickup truck I repainted, the stuff became dull pretty quick and chalky, I was far less than impressed.
I know a vet's office Ive been to seem to have a rubberized floor, you had the impression you could just hose it all down to a floor drain in the middle, it was nice stuff. I bet it came in a roll and was glued down but beyond that I have no idea about it, seems a lot better than epoxy paint.
pete0403 07-06-2013 08:18 PM
Thanks for the comments.
There's no drain in the room as this is the upper basement of a split-level. We were worried that a rubberized floor would be hard to sweep and clean...also wear excessively around the grooming table and bathroom.
Open to all suggestions though. One other possibility is vinyl...glued sparingly so it could be replaced easier.
joecaption 07-06-2013 09:24 PM
The best way would be to tile it with porcelain or ceramic tile directly to the slab.
pete0403 07-08-2013 01:51 AM
Thanks guys...
...how could I go about etching the floor without chemicals?
ccarlisle 07-08-2013 08:02 AM
You might want to look into the 'Diamabrush' setup, that runs off a 175rpm swing machine. Am not 100% sure of myself here, but if that setup can remove paint etc from floors, I am pretty sure it can etch it too.
