Estimated Time To Install Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 08:29 PM   #1
Estimated time to Install Underlayment
What will be estimated time to install underlayment in 1100 sq. ft area ?
THe material - 5/8" plywood needs to be screwed onto wooden sub-floor.
I need the estimates to ensure I am being charged reasonably by my contractor.
lucknowm is offline   Reply With Quote
Old 03-05-2008, 08:38 PM   #2
ICF Construction
Wide open...meaning perimeter cuts only, 1 day, 2men...interior and all cut up 2 days, 2 men maybe a day longer depending on how much cutting and fitting.
Add more time if he is moving your personal belongings, appliances, etc.
Chris
Chris Johnson is offline   Reply With Quote
Old 03-05-2008, 08:40 PM   #3
What is perimeter cut and interior cut ?
Old 03-05-2008, 08:46 PM   #4
ICF Construction
If you are doing a basketball court and only cutting around the edges that's the perimeter, if you are doing a main floor of a house with 3 bedrooms all the various interior walls are interior cuts
Chris
Old 03-05-2008, 09:02 PM   #5
What is the best way to cut fiberock? I have used hardibacker before and just used a jigsaw. Is fiberock any diff??
danp4 is offline   Reply With Quote
Old 03-06-2008, 07:26 PM   #6
Tile Contractor
Bill_Vincent's Avatar
Should be somewhere between 1100.00 and 1650.00 for labor
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 09:41 AM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 06:54 PM
