Epoxy Paint And Mastic Remover - Flooring - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 09:57 PM   #1
Rewards Points: 18
Question
Epoxy Paint and Mastic Remover
I have a utility room I'm planning on painting with rustoleum epoxy floor paint. The problem is I ripped up old carpet and there is old carpet glue on the concrete under it. I tried scraping as much as I could off but it just isn't going to come off. What other options do I have? Can I use a mastic remover? Will it affect the bond with the paint if I do. Thanks for your help in advance.
fuzzbutter is offline   Reply With Quote
Old 07-09-2012, 11:12 PM   #2
Rewards Points: 14,306
What's the subfloor? Slab, plywood, OSB?
Old 07-09-2012, 11:19 PM   #3
Rewards Points: 18
It's a slab
Old 07-10-2012, 05:48 PM   #4
Rewards Points: 264
I would suggest renting a grinder you can get them at most tool rental shops.
Awoodfloorguy is offline   Reply With Quote
Old 07-10-2012, 05:58 PM   #5
Rewards Points: 18
just like a small hand grinder?
Old 07-10-2012, 06:02 PM   #6
Rewards Points: 264
Yes, that's what I would go with unless the area is really large, then maybe consider a large walk behind one.
Tags
epoxy , floor , garage , mastic , paint
Epoxy paint over black mastic over concrete in basement kidnitro6 Flooring 0 03-21-2012 02:50 PM
cover mastic with paint ebert123 Painting 1 12-21-2011 06:58 AM
Asbestos tile and mastic phillyDIYER Flooring 14 08-21-2011 01:46 PM
How can I smooth my bumpy slabs in preparation of epoxy paint/coating? joeyboy Painting 5 02-13-2008 07:12 PM
Paint/seal over black mastic KBO123 Flooring 1 12-06-2005 02:11 PM
