-   -   Epoxy Paint and Mastic Remover (http://www.diychatroom.com/f5/epoxy-paint-mastic-remover-149745/)
fuzzbutter 07-09-2012 09:57 PM
I have a utility room I'm planning on painting with rustoleum epoxy floor paint. The problem is I ripped up old carpet and there is old carpet glue on the concrete under it. I tried scraping as much as I could off but it just isn't going to come off. What other options do I have? Can I use a mastic remover? Will it affect the bond with the paint if I do. Thanks for your help in advance.
joecaption 07-09-2012 11:12 PM
What's the subfloor? Slab, plywood, OSB?
fuzzbutter 07-09-2012 11:19 PM
It's a slab
Awoodfloorguy 07-10-2012 05:48 PM
I would suggest renting a grinder you can get them at most tool rental shops.
fuzzbutter 07-10-2012 05:58 PM
just like a small hand grinder?
Awoodfloorguy 07-10-2012 06:02 PM
Yes, that's what I would go with unless the area is really large, then maybe consider a large walk behind one.
