Epoxy Grout? Suggestions - Flooring - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 09:44 AM   #1
Rewards Points: 156
Just got done with an outdoor tile job on my back patio. Still need to grout it.
Should I use epoxy grout since it is outside? I heard it is a pain to work with. If I need to use the epoxy, anyone have any suggestions on what brand to buy and the best way to work with the stuff?
If not epoxy, what other grout would be suitable for outdoors?
Branden is offline   Reply With Quote
Old 08-09-2010, 12:57 PM   #2
Rewards Points: 156
Well I did some more research and it sounds like epoxy grout is some really tough stuff to work with.
Laticrete 1500 says it's approved for indoor/outdoor use, and is mold/mildew resistant when mixed with their special blend. The area under the tile is waterproofed. Not sure how the 1500 would hold up to the outdoor temperatures though, and I still would rather have my grout waterproof. Any insight from anyone?
Old 08-09-2010, 01:32 PM   #3
I used epoxy grout on my kitchen countertop. Not hard to work with at all. I don't think that I would use it for a large scale application. Way too expensive.
unlvrebel is offline   Reply With Quote
The Following User Says Thank You to unlvrebel For This Useful Post:
Branden (08-09-2010)
Old 08-09-2010, 02:02 PM   #4
Rewards Points: 156
Hey UNLV, would you mind telling me what brand epoxy grout that you went with?
Old 08-10-2010, 06:48 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Laticrete Spectralock or Mapei Opticolor are the Epoxies to go with. There are other higher end products but you are getting into full scale epoxies that are a pain to work with. Spectralock and Opticolor are both fairly easy if you watch your time and make sure you clean it correctly. It does get expensive though on a large application.
poppameth is offline   Reply With Quote
epoxy grout on glass tiles? zootjeff Tiling, ceramics, marble 1 07-04-2010 08:21 AM
Epoxy Grout Removal FLWRCHLD Flooring 2 05-27-2009 12:02 AM
Repairing Epoxy Grout? Ed Coles Flooring 2 01-22-2009 07:40 PM
Grout suggestions ahg Flooring 2 03-22-2008 09:52 PM
epoxy grout?? samiam Flooring 1 12-04-2007 10:24 PM
