Old 08-28-2008, 10:42 AM   #1
Cool Epoxy Grout Removal
Newbie here...I have been searching for an effective way to remove Epoxy Grout. So far it a'int lookin good (thank goodness it's not my house). Any help on this subject will be much appreciated. Peace to you and yours!
FLWRCHLD is offline   Reply With Quote
Old 08-28-2008, 11:11 AM   #2
Are you looking to remove it from the grout lines or on the tiles or something else?
A heat gun will soften it for removal but could damage the product you are removing it from.
A wire brush on a drill if the surface is very hard.
I've heard this works great: http://www.aldonchem.com/pr-premium-stripper.htm
Also, Mapei makes something called Keraclean epoxy grout film remover.
KHouse75 is offline   Reply With Quote
Old 05-27-2009, 01:02 AM   #3
with 5 kids figured try it but very course and dirt stiicks in there, sponges get torn. I dont want to damage tile but if I havt to damage some OK, any ideas
justus1933 is offline   Reply With Quote
More On This Topic
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how to clean the grout. In our last segment, I used an acrylic grout versus a sandy or a non sandy grout. Typically we would use a sponge... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how the apply the adhesive for your new floor installation in your basement. The first thing I want to do is because I am working in a small... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and now I am going to show you how to put the material back into the adhesive. You are going to start up by rolling the material slowly back into the adhesive. Making sure to try... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. Now in this segment, I am going to be showing you how to set your tile and applying the mud to the floor. We would let our mud slack off after mixing it for 10 minutes. I have a... Read More »
another grout color change question tryinitmyself Flooring 1 02-22-2008 08:50 PM
Tinting/re-coloring grout proofer Flooring 7 02-03-2008 12:59 AM
epoxy grout?? samiam Flooring 1 12-04-2007 11:24 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 09:49 PM
Bathroom Caulk/Mildew Removal ChrisBianchi Remodeling 4 02-01-2006 02:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
