Epoxy Garage Flooring
14K views 37 replies 13 participants last post by  yesitsconcrete
#1 · (Edited)
Hi guys, I'm thinking of laying epoxy onto my new cement garage floor. I've heard some bad things about the epoxy peeling after 2-3 yrs. To anyone using epoxy for their garage flooring, how is it holding up? I've read on the 2 other epoxy threads and it's helped me a lot. Thanks.
#4 ·
I have been researching different concrete treatments.
My thought is that a polished slab is the best possible scenerio. It is what I plan to do to my slab.
Paints, epoxys and sealers will deteriorate over time. The most permanent, maintenance free finish is a polish. Even still this requires alot of prep and an occasional buffing here and there depending on use. However, I think it might be worth it, in my case.
I guess it is what you want, versus what you want to upkeep.
The moisture test is to put water on the slap and see if any area beads up. Like wax on a car. In those places the sealer/epoxy will not adhere.
Perhaps someone more experienced will chime in.
I am interested in this subject as well, and I wish you good luck.
#5 ·
Well, one of the main things you want to establish in a concrete slab in a garage setting is the amount of moisture underneath it and how much of that will permeate into the garage space itself, as Bud says. For that, you do a simple test to see what is coming through. You tightly tape down a square foot of plastic onto the floor and let it sit for 24+ hours. Clear plastic is best. Take it off and note the amount of water on the underside of the plastic. None = you're OK to go...but more than a droplet or two means that somewhere down the road, the finish you put onto the floor will lift.
Epoxies give you great shine and resisitance to garage chemicals (oil, gas etc) and the better systems are 2-components mixtures of resin and hardener. But no matter what you pay for an epoxy floor, the key is in the prior preparation of the concrete. Best is if it's been cleaned and neutralized...smooth, of course, and no cracks. Already that's a tall order for any floor and a huge requirement for any system - but the more you put into it now, the better the final product.
The best epoxy is on top of a dry, insulated, clean and polished floor. :( ...Like marines, few are chosen...
#7 ·
The calcium chloride test is not within the means of every DIY'er out there; contractors use it sometimes but not homeowners.
The plastic film test is a visual, not a quantitative method to give you an idea of what may be a problem. For exact % moisture under there and what to do or not to do with your slab or foundation, go for the calcium chloride test. But you'll get a good idea what the extent of your problem will be.
:wink:
#8 ·
Moisture contents in slabs can change seasonally, there are other reasons that a slab can collect and emit moisture. The "plastic" test is a good start. If moisture develops then of course you know it is there and would want to pursue that issue using the Ca Cl (cackle - Calcium Chloride) test which will determine "how much" moisture is present, AT THAT TIME. All floor coverings have their limits when it comes to the moisture content of a slab. This includes topical coatings.
Ca Cl tests are used routinely by professional floor covering installers and retailers but can be costly in some opinions. Even if your floor has no moisture at this time doesn't mean it never will. At lot of factors determine when and how a cement slab attracts moisture.
If you were to entertain an acid stain finish the floor could then be coated with a "vapor-transmissive" sealer that would allow the floor to breath and would likely save the surface from delaminating over time if moisture was ever present.
#10 · (Edited)
Norman R: I use ordinary paint thinner to clean rubber bicycle tire marks off of acrylic floor finish. Try that first. If that doesn't work as well as you like, try using a Magic Eraser to remove those tire marks. Other than that, I'd suggest that a regular sweeping and occasional damp mopping would be all you'd need. Epoxy is very stain resistant.
Carlisle said "You tightly tape down a square foot of plastic onto the floor and let it sit for 24+ hours. Clear plastic is best. Take it off and note the amount of water on the underside of the plastic. None = you're OK to go...but more than a droplet or two means that somewhere down the road, the finish you put onto the floor will lift."
A.) Why one square foot of plastic? Why wouldn't you get exactly the same results regardless of what size of plastic sheet you use?
B.) The problem with this is that it's an "all or nothing" measurement. If you don't see any water under that plastic when you pull it up, then you conclude there is ZERO moisture coming through the concrete, and that's not necessarily true. Had you left that plastic taped down for a little longer, you very well could have found condensation under it.
A better way is to buy a cheap hygrometer (measures relative humidity) from Lee Valley or any hobby shop. Slip that under the clear plastic and tape it's perimeter down to the floor. That way you can tell what's happening under that plastic while it's still taped down. You might find that the hygrometer needle goes from 30 to 90 percent in 26 hours. Without the hygrometer, you'll conclude that there's no moisture coming up through the concrete, and that would be wrong. You'd end up like so many others with peeling epoxy paint on your garage floor.
Also, the hygrometer doesn't have to be accurate or precise; a cheap one will do fine. You don't care what the hygrometer reading is, only whether or not it's detecting an increase in the humidity.
C.) Since this is a garage floor and not a basement floor, we need to mention that condensation depends on relative humidity, and relative humidity depends on temperature. If you put the plastic down during the heat of the day, you could find condensation under it at night, which may be gone again the following day. Also, falling day time temperatures could create condensation even if you don't have moisture coming out of the slab, and increasing day time temperatures could prevent condensation from forming even if water is coming out of the slab.
A concrete slab is a particularily good thermal mass. It's great weight means that it takes a long time to heat up or cool down to the temperature of it's surroundings. That means it maintains a much more consistant temperature from day to night, or over the span of several days and nights than ambient temperatures. So, if it wuz me, I'd lay a batt or two of insulation over that plastic to also keep the air under the plastic at that same relatively constant temperature too. Then, just pull up the batt(s) periodically to check the hygrometer reading to see if it's going up or not.
Drill Bit - Wouldn't polished concrete be pretty slippery when wet?
What about putting something like old scrap carpet (liberated from the dumpsters behind carpet retail outlets) on top of the concrete in winter? That would ensure good traction even when wet. Only problem is that then you couldn't see that nice polished concrete floor, only ugly old wet oil stained carpeting salvaged from someone's house. I like the idea of polished concrete because it wouldn't be as porous and wouldn't stain as easily as ordinary concrete floors. But, any smooth surface is slippery when wet, and that would be a definite disadvantage in places where snow falls in winter.
So, whaddaya think Bud? Did I just copy and paste this stuff out of some "Garage Floors 'R Us" website? Here's a hint:
http://www.garagefloorsrus.com
#11 ·
I did some research on the topic a couple months ago. I plan on doing my garage floor, but I won't have time till spring, so I don't have first hand experience.
I found this product: www.epoxy-coat.com It is more of a commercial version of epoxy floor coating and is suppose to last more like 20 years. It is fairly expensive, but I like things I only have to do once. I plan to buy there product when I am ready to do my floor.
They respond to my e-mail messages with questions about there products. They also have some useful info on there web site and some photos of garages that were painted with there product -- they look really really sharp.
Jamie
#13 ·
I just picked up a couple of brochures on epoxy for the garage floor. There's products by Rust-oleum and Quikrete. Is one product better than the other? It says that it takes 3 hours to put down. I know the prep work will take a lot longer (getting up the oil stains, sealing the cracks, etc.). Has anyone done this recently that can share their experience? Do's and don'ts that I should know before going in? With these color flakes in the kit, although they call them "decorative," it seems like using them will also make it more skid-resistant.
#14 ·
they're both fine &, probably, made by the same private labeler,,, 1 especially nice feature is the ease in which they're remov'd next year when you need to diy over.
we can't use them because we have to guarantee our work but that shouldn't stop you a bit,,, fwiw, my daughter's b/f decided to do her floor just as a favor :laughing: w/apron store mtl,,, think it lasted 1wk before hot tires started to pick up the finish :whistling2:
who says cracks have to be sealed, how prep'd, & w/what sealant ? ? ? if you seal the crks w/epoxy, they'll just reflect back,,, if you seal w/sealant, epoxy won't adhere,,,
vinyl flakes're for hiding imperfections in a poorly laid floor rather'n add skidproofing imn-s-hfo,,, since most of our epoxy floors're protected w/urethane top coats, we don't often use flakes,,, my own garage'll have acid-stain/urethane (7d keep-off-it) OR poly-aspartic (1d k-o-i),,, my bride hasn't decided yet :thumbsup:
#16 ·
just relating what i've seen when redoing other's diy projects w/apron store coatings,,, our epoxy mtl COST for a 24x24 garage = $576 w/o frt OR the topcoat of aliphatic urethane protective sealer,,, nor does it include consumables used prep, mask mtls, OR for discarded tools that cannot be reused/cleaned.
you have to remember that, as w/h-o's & diy-ers, not all epoxies're created equal,,, also, its not uncommon for diy-ers to accept sub-standard work,,, we wouldn't have that boon.
many times i'll hear an apron store employeed giving advice to h-o's that is ABSOLUTELY wrong but usually thru ignorance, not maliciously intended,,, this, in no way, suggests that ALL products they sell're poor quality - eg, i buy their hardibacker for sampleboards but bluetape comes from sher-wms.
#17 · (Edited)
YesIt'sConcrete:
Who's epoxy do you use? You seem to be suggesting that epoxy peeling on garage floors is mostly a matter of stores selling, and DIY'ers using, less expensive (and by implication) lesser quality epoxy. Besides cost, what is the difference between the epoxy paints you use in your business and the epoxy paints Home Depot sells? And, are you saying that your epoxy garage floor paints would NOT peel under the same conditions that a Home Depot garage floor epoxy paint would peel? My understanding is that epoxy paints are a "mature technology", meaning that there's been no major changes in that technology for some time. Usually, that means that everyone making that product is producing much the same thing as everyone else.
PS: You don't need to know the rest. It explains what 'YesIt'sConcrete" meant when he said "aliphatic urethane". He really meant a moisture cure polyurea that uses an aliphatic di- or tri-isocyanate.
An "alcohol" is anything that has a hydroxyl group (-OH) bonded to a carbon atom. That is, C-OH
A diol or triol is anything with two or three, of them, and a polyol is anything with even more of those things in it.
An "isocyanate" is anything with an -N=C=O group in it.
A di-isocyanate or tri-isocyanate is anything with two or three of 'em
and a polyisocyanate is anything with even more.
You make a polyurethane by allowing a di- and tri-isocyanates to react with polyols. And when that happens:
R1-N=C=O combines with HO-R2 to form R1-(NH)-(C=O)-O-R2
where R1 and R2 are anything with isocyanate and hydroxyl groups in them and that ugly thing that forms between them is a urethane linkage. There's a much better drawing of a urethane linkage here:
http://en.wikipedia.org/wiki/Polyurethane
"Moisture cure polyurethanes" are a special class of "polyurethanes" where instead of having two separate reactants, one with isocyanate groups in it and another with hydroxyl groups in it, you only have that first reactant with the isocyanate groups in it, and it reacts with the H-O-H (water) in the air! Get it? The isocyanates see a water molecule as being two connected hydroxyl groups and reacts with it to form something similar to polyurethane, called a "polyurea". All moisture cure "polyurethanes" are actually "polyureas", not polyurethanes.
In the case of a moisture cure "polyurethane", the reaction goes like this:
R1-N=C=O reacts with H-O-H to form R1-NH2 and CO2 (which gasses off)
(aside: Ammonia gas is NH3. If you replace one of the hydrogens in ammonia with something else, the compound you get is called an "amine".)
the amine that's formed (R1-NH2) then reacts with another isocyanate to form a urea group, like this:
R1-NH2 and O=C=N-R1 forms R1-(NH)-(C=O)-(NH)-R1
And that (almost as ugly) thing in the middle is a "urea" group.
Now, if each R1 has two or three isocyanate groups in it, you can see how exposing a blob of R1 to high humidity would result in a solid polyurea being formed. H2O from the air would react to form urea groups between each R1 molecule and all it's neighbors. That would cause a soft blob (or puddle) of R1 molecules to form a hard hunk, or hard film, of polyurethane plastic.
http://en.wikipedia.org/wiki/Urea
http://en.wikipedia.org/wiki/Polyurea
Now,...
When they say "aliphatic" isocyanate, that word "aliphatic" refers to the nature of the thing at the center of R1, or the thing all the isocyanate groups are connected to. It will typically be a hydrocarbon, which means something made out of carbon and hydrogen atoms that is typically a byproduct of refining crude oil.
Hydrocarbons like propane and benzene are broken down into two general catagories, aliphatic hydrocarbons and aromatic hydrocarbons. Aliphatic hydrocarbons are ones where the carbon atoms are lined up in a row, like propane and butane. Aromatic hydrocarbons are ones where the carbon atoms form rings, like toluene, xylene, benzene and naphthalene and Buckyballs. Generally, aliphatic hydrocarbons have very little smell associated with them, wheras aromatic hydrocarbons have a fairly strong smell. Naphthalene is what moth balls are made of, and they stink.
One of the disadvantages of using aromatic hydrocarbons with isocyanate groups on them as the R1 in our example above is that moisture cure polyureas made using aromatic hydrocarbons tend to yellow with age. If you use an aliphatic hydrocarbon with isocyanate groups on it, and allow it to react with H2O, the polyurea you get won't yellow with age.
For those that are interested in this stuff, this web site covers the subject well:
http://www.pcimag.com/CDA/Articles/Feature_Article/BNP_GUID_9-5-2006_A_10000000000000431366
Also, it should be emphasized that the kind of "polyurethane" we're talking about here has very little in common with the oil based "polyurethane" we use as "varnish" or hardwood floor finish. Read on...
When you make the alkyd resins for "oil based" paints, you cook together various chemicals (including glycerine) together. If you want to make an alkyd based "polyurethane" resin for polyurethane "varnish" or polyurethane hardwood floor finish, you add some di- or tri-isocyanates to the recipe. Glycerine molecules have three -OH groups in them and so the isocyanates you add react with the those hydroxyl groups to form urethane linkages right inside the alkyd resin, making it a "urethane modified alkyd" or "polyurethane" resin. Those urethane linkages are very strong, and they act inside the alkyd resin very much like a roll cage inside of a race car, making that resin much harder if you tried to crush it, and much stronger if you tried to stretch it.
So, for "oil based" polyurethanes, all the urethane linkages are allready formed inside the resins when the can leaves the factory. No urethane linkages form when the product is applied to a substrate.
With the kind of polyurethanes YesItsConcrete is talking about, the urethane or urea linkages form once the product is used, not before. And, because there end up being very many more urethane linkages formed in the isocyanate based polyurethane film than in the "oil based" polyurethane film, these isocyanate kind of of polyurethanes form very much harder and more durable films than the "oil based" polyurethanes do. The only thing the different kinds of polyurethanes have in common are that they all contain urethane or urea linkages, but beyond that, they're completely different and their properties are all different too. So, some polyurethane coatings are very much harder and durable than other polyurethane coatings.
But, if someone just calls something "polyurethane", it's safest to presume they mean the "oil based" stuff cuz most people don't even know about the isocyanate based stuff.
#18 ·
since i have no financial interest/benefit in any possible sale, its sold by elitecrete &, to my knowledge, manufactured by the same company,,, its only avail thru their dedicated distributor network & only applied by licensed applicator/artisans,,, eg, i couldn't sell it to you,,, if there was a suggestion failing final product is caused by less-than-comparable-quality-mtl &/or less-complete prep, i'd guess the answer'd be ' i don't know ! ',,, do know we've replaced those coatings & seen evidence of same.
i'm not qualified/educated to know much about epoxy paints's chemistry,,, since i've never seen a paint stay on conc,, hell, i don't even know how that term's defined OR even if its defined correctly w/i what discipline - chemistry, construction, coatings, etc,,, we use coatings aplied over acceptably prep'd conc,,, we coat conc w/mtls avail to pro's which, i DO suggest, aren't inventoried at apron stores,,, that shouldn't be understood as not buying anything job-related from such source,,, we would buy portland cement :) wouldn't it be funny if the stuff ' there ' turned out to be private-label'd for them by ykw but w/their recipe & ingredients ? ? ?
let's also be clear that quality of ingredients does have an effect on finished products,,, doubtful i mention'd store's name or color of apron as its not germaine.
' PS: You don't need to know the rest. ' - WOW, i AM impress'd - did you google that information, write it off the top of your head, or copy it from a book or label ? ? ? :yes: its even more'n i want to know,,, all this talk about urea & polyurea - i gotta go pee :whistling2:
thanks for taking the time & expending the effort, nestor,,, have seen evidence of your knowledge/experience in other posts & its appreciated.
#19 ·
I have recently applied the quikcrete epoxy kit to my garage floor, with the third step of Quikcrete Epoxy sealer from the the gallon can. I would like to go ahead apply the clear coat from the Kit. CAn someone tell me if this will work on top of the sealer I already have?
#20 · (Edited)
Any paint company that has a decent industrial line will have an epoxy floor coating that will far outclass the quickcrete and rustoleum products. The main thing to remember about these box store products is that they are usually water-based. The true industrial products are solvent-based and far tougher. Both Rustoleum and H&C make both waterborne and solvent based products, though the water-based are the only ones you commonly see in stores.
There are other products out there as well that work just as well without all the hassle. Pratt & Lambert for example makes a high solids urethane coating that comes in clear and 4 colors. It's potent stuff to work with since it has harsh fumes. Comes only in high gloss as well. But, a co-worker put this stuff on his friend's new garage floor several month ago with great results. One coat of a beige color and one coat of clear with Sharkgrip texture added to it, which gave slip resistance and knocked the gloss down to a satin. The stuff has held up beautifully so far. It was far less work to apply as well since you don't need to worry about pot life. There is nothing to mix together with this stuff. I does still cost about as much as the epoxy kits do though. It's lasted longer already than I've seen some of the Sealcrete and Rustoleum products last though.
As far as moisture in the slab, every professional industrial coatings company I've asked about this tells me the same thing.
1) there must be a vapor barrier in the slab. This means that a layer of plastic should have been laid on the slab before the final pour. If this isn't present no manufacturer will warranty the product you put on it (and since it isn't easy to tell if it's there after the fact they won't warranty it anyway). Without the vapor barrier every tech guy I've talked to at these companies pretty much guarantees it will peel at some point.
2) they all spec a Calcium Chloride test to check for moisture anyway.
#22 ·
The longest manufacturer warrnty on any epoxy floor is 5 years. that is applied by a professional taking three days to complete two of which are grinding and/or acid wash. That speaks volumes for how long this product is expected to last.
These people: http://www.epoxy-coat.com/ say they put a lifetime guarantee on their commercial epoxy floor product. Do you think it still really only lasts 5 years?
I am planing on using this product in the spring on my garage floor. It is a expensive and time consuming process to apply the commercial epoxy type of product that they sell on this web site, I would sure be unhappy if it was having problems in just 5 years.
Jamie
#23 ·
Epoxy Coatings
I was in paint manufacturing for almost 25 years. With epoxy floor coatings there are so many variables. Chemicals, acids, lime in the concrete mixture then moisture, pressure and vapors all rising and wanting to pass thought the substrate and the product applied. Then you have tires and all of their chemical make ups, setting on top.
If the manufacturer decides to make his product a solid surface (as n barriers) then moisture and chemicals cannot pass through the pours so it blisters. If you make the product porous then it is susceptible to absorption, which can lead to staining and/or degradation of the product.
My bets on garage floors. But they have their issues. Ceramic is expensive and hard to install. Race deck is hard and clunky and the holes are hard to clean, FlexiTile is not cheap but less than ceramic and not clucky and hard to clean. Ceramic will last a life time, Race deck has a ten-year and flexitile has a 25 yr. Warranty.
#24 ·
When you say ceramic are you just talking about regular ceramic floor tiles, the kind that people put in their Kitchen and such? ( I am installing some on my porch right now ) ?
I have found ceramic floor tiles that are rated as the highest level of hardness that are well less than $1 /sqft. For the epoxy stuff I was looking at, it would be atleast $1 /sqft by the time I am finished with it.
I agree that the ceramic tile (well atleast the kind you install inside) are a lot of work, spreading the thinset and cutting the tiles.
I am curious if we are both talking about the same kind of tile.
That is my porch that I am working on, so could I install this same kind of tile in my garage? If so, I assume I would want to use the more expensive thinset that is rated for unheated space. My garage floor is very stable. No cracks, but some fairly minor surface damage (chips and such from physical abuse, salt, etc.)
Jamie
#25 ·
what's the big deal,,, tile's tile work,,, $1,00sf's cheap apron store tile & our wholesale cost on epoxy's double,,, you're thinking as a h/o, not a pro,,, anyone who'd place tile on any exterior surface should realize freezing temps'll eventually loosen it - even in atlanta,,, most garage floors aren't candidates for epoxies which's why we use polyaspartics, methyl-methacrylates, or urethanes.
pro's mtl's rarely advertised where h/o's-diy-er's could even see it listed,,, sonneborn's got decent stuff as does natl polymers but its doubtful any diy-er could find it as its not their work,,, those guys focus on architects, specifiers, engineers, govt, & dot's,,, you have to be in the arena often to find the stuff & know how to do it,,, gaining experience from reading labels, visiting websites, & watching dvd's fun but pointless,,, IF you get customer no-svce on the line, what's the chance they won't be reading from the same information,,, getting a decent field rep's impossible when your total invoice's 2 units,,, try a truckload & you'll have friends, tho.
watch a tv show or visit an apron store, tho, &
VOILA ! ! - I GOTTA HAVE IT and I CAN DO IT MYSELF ! ! !
#26 ·
Epoxy Coatings
Urethanes, Epoxy, waterborne products all face the same challenges with floors especially where there are no controlled temperatures. Ceramics are used exterior in all types of settings. You can find them outside hotels, in courtyards from Texas to Maine. I live in Kansas City (can get to –18) and I have seen a lot of ceramic tile in garages. You do have to buy the right tile. Any good tile reseller could help you with choices. What you use to bond the tile to the substrate is the biggest variable. You might have paid $1.29 a sq. ft. for the tile but what are you paying for grout, sealers, mud and labor?
#27 ·
Any porcelain or quarry tile will work out of doors in most any climate. Make your own modified thinset mortar by using an additive with unmodified thinset and you'll be just fine. Cement grout is basically cement grout and they all work outside. There is no reason to think the tile will ever loosen just from being outside.:)
Ceramic tile is used in harsh climate all over the world, no big deal.:)
#28 ·
not to disagree w/my newest & bestest friends andy & bud - but putting tile outside in a freeze that environment's a waste of time imn-s-hfo,,, yes, it looks 'nice' - but it ain't permanent,,, just the fact tile's outside is not the issue - its WATER INFILTRATION into the jnts which freezes & lifts tiles,,, even here, 10yr life's about all you can expect before degradation & bond loss begins.
latex-modified mtls do work better but not all setters use 'em,,, don't get me started on the cheap indian slate garbage,,, that's a nitemare even tho the 'queen' thought it beautiful.
just my experience.
