Epoxy Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 04:54 PM   #1
epoxy flooring
My garage floor has been painted and it is peeling. I was thinking about covering it with an epoxy paint with chips - can this be done or does the floor need to be completely stripped of the origianal paint?
mpkrob is offline   Reply With Quote
Old 02-13-2011, 05:45 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it would have to be stripped. If for no other reason, putting the epoxy on top of something that is already flaking off would not remedy the flaking problem. It might look ok for a short while but since the base coat is already loose, it wouldn't stay that way for long.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
How can I remove dried epoxy resin from hardwood flooring? Kay Manuel Painting 1 03-22-2010 08:41 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Epoxy Garage Flooring boba7523 Flooring 37 02-28-2009 09:24 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
