Epoxy Floor Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 04:26 PM   #1
Rewards Points: 205
Just returned from the Miami Beach Home Show. Pretty weak lineup of folks. I did see a couple guys selling epoxy floors. These are not just coatings over concrete, this is a coating approx 1/16" to 1/8" with design elements in them. Wish I had a website link to post but I don't right now.
I'm the guy with the ceramic tile over hardwood floor. So I know I need to remove the tile first. As long as the HW is in good condition, one of the guys said he could go over the hardwood. I'm wondering if he is just trying to get work or if it would be durable. I like the idea of the floor. Just wondering about durability and if it could indeed go over HW.
Anybody have any experience with this product?
Thanks in advance.
CosmicMiami is offline   Reply With Quote
Old 03-23-2013, 05:00 PM   #2
Rewards Points: 13,444
Never seen it but due to the wood flexing and expanding and contracting, I'd want it in writing with a money back plus labor warrenty.
Old 03-23-2013, 05:14 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
I have never heard of that being done.....not to say that it wouldn't work....but.....one thing I'm sure of....if the hw is not perfect, all the defects in the surface will show up....
I know DIY frowns on links to other sites......but....the below link takes you to a flooring section of a web site that is JUST about garages....read through some of the posts the guys have about epoxy floors....then decide if you really want to go that way....
http://www.garagejournal.com/forum/f...splay.php?f=20
On a side note....I think it would border on having that 'trailer trash' look.....
Old 03-23-2013, 06:20 PM   #4
Rewards Points: 205
When finished, these look like a stained concrete finish with a sheen. If you can imagine a nice, new, shiny terrazo floor, that's what they look like. I was a little suspect when he said no problems over HW.
I once had an adhesive guy tell me that he can glue anything to anything. The problem is when temp changes, different products expand and contract at different rates and that's when the adhesive fails.
When I get home I will pull out the brochures and see if there is a link to this product.
Old 03-23-2013, 06:46 PM   #5
JOATMON
ddawg16's Avatar
I think you have the right attitude and approach.....research.....I'm sure it looks good...but unless the stuff is really flexible...I can't see it being used on HW over a crawlspace.....now, if the HW was on top of concrete...then it might work better.
Old 03-23-2013, 07:19 PM   #6
Rewards Points: 166
Some of the things they are doing with epoxy floors these days are really outstanding. It's not just the typical old garage stuff with multi-color flakes anymore.
I've seen it done over tile and linoleum, but not over HW. I would also be concerned about expansion/contraction. Definitely ask for something in writing, and ask to see an example too.
dftc is offline   Reply With Quote
Old 03-25-2013, 07:43 PM   #7
retfr8flyr's Avatar
Give Fred a call at (408)692-5742 if anyone can tell you if this is possible he can. Fred is the exclusive distributor for Wolverine coatings DIY division and these guys make coatings for just about everything you can think of. I just order the material to do my garage from Fred, after researching coatings for several weeks.
Earl
retfr8flyr is offline   Reply With Quote
Epoxy floor sealer Timalin Concrete, Stone & Masonry 0 07-12-2012 10:54 PM
I need help - Epoxy over foam board tibberous General DIY Discussions 13 01-26-2012 11:03 AM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 03:41 PM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-17-2008 11:32 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
