Old 11-01-2009, 12:01 PM   #1
Epoxy Floor Prep?
I'm getting ready to coat my garage floor with a two part epoxy coating. The floor is only about 5 months old and is perfectly clean except for a few light splatters of paint from when I painted the walls. Is it necessary to clean off every last splatter of latex paint off the floor before I do the acid etch and lay down the epoxy?
Thanks!
mopowers is offline   Reply With Quote
Old 03-25-2010, 03:02 PM   #2
Thumbs up
Epoxy Floor Prep?
Been professionally installing epoxy garage floors since 2004.
It is not ABSOLUTELY necessary to clean off a few latex paint drips from the floor prior to laying the epoxy . . . BUT an ounce of prevention is worth a pound of cure. You can get a latex paint stripper at any hardware store for a couple of bucks. At the very least, sand down the drips to a scuffed up surface so the epoxy has something to grab onto.
Patrick
California Concrete Restoration
http://www.squidoo.com/epoxygaragefloors
calconcrete is offline   Reply With Quote
Epoxy paint Bathtub Refinishing? Lovegasoline Plumbing 7 10-29-2009 04:58 AM
Epoxy Garage Flooring boba7523 Flooring 37 02-28-2009 10:24 PM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-18-2008 12:32 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
