Epoxy Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 08:59 PM   #1
Ok I need advice so that I can do thugs right. I have a home with an upstairs room which is just a large empty game room. The room currently has carpet and plywood subfloor. What I want to do is apply a high gloss epoxy flooring. I was told that I will first need to install greenboard or cement backer board on top of the subfloor. From there I'm not sure how to prep that for the epoxy if someone can give me advice it would be great. I included a picture of what our goal is.
Thank you
diaz1109 is offline   Reply With Quote
Old 09-06-2011, 02:25 PM   #2
Anybody??
Old 09-06-2011, 04:05 PM   #3
amuffly's Avatar
http://garagejournal.com/forum/showthread.php?t=2873
amuffly is offline   Reply With Quote
Old 09-06-2011, 04:30 PM   #4
Thanks for the reply but that like had not much to do with my question.
Old 09-06-2011, 05:16 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Where the heck are you getting your information so far?
Do you have your terms correct?
Greenboard is a drywall material for walls...there is no way it could ever be used on a floor.
Wait a minute I'm going to go back and read your first post again, it is too far off base for me to have read it correctly the first time.
I'll be damned! yup that's what it says.
So anyway the green-board is out.
Now, the cement board.
Cement board is used for an underlayment for ceramic and stone tile. Standard cement board always has quality control issues and it also wouldn't work for this purpose. You would never get it smooth enough to do what you are wanting to do. The alternative is "fiber cement board" which is a lot smoother to start with but there is no way to make the joints smooth. Then there is the issue of the imperfections that will be created by the fasteners you use.
Next I suppose there are cost constraints, is that correct?
Where did you get the picture?
XXX
Old 09-07-2011, 05:20 PM   #6
That picture is my goal I found it online. A contractor buddy of mine told me today I can add thin plywood on top of the existing subfloor add wood filler to cover all the sunken screws and gaps where the plywood edges meet then sand everything down till it's super smooth. After doing that I would prime then paint the floor white with two coats. After it's dried for 24 hours add a few coats of super high gloss epoxy that should get y floor looking like the pic. The best part is I avoid the use of concrete. Let me know what u think about this process.
Old 09-07-2011, 08:58 PM   #7
amuffly's Avatar
If the house settles or you have any movement the thin plywood would just show cracks in the epoxy. The reason I gave you that site was so that you could call the epoxy companies and see what they recommend.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 08:01 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Epoxy Garage Floor Paint Ferguson105 Painting 2 09-26-2010 02:20 PM
Epoxy Floor Prep? mopowers Flooring 1 03-25-2010 02:02 PM
