Epoxy Coating - Flooring - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 08:57 PM   #1
retfr8flyr's Avatar
Epoxy coating
I am going to do my garage floor with epoxy and I am trying to decide how much chip content to use. It has been recommended by several company's to do a full broadcast of the, for durability, chips instead of just a few chips. Does anyone have any experience with this method?
Earl
retfr8flyr is offline   Reply With Quote
Old 03-18-2013, 09:56 PM   #2
Rewards Points: 12,794
DO a full coating, looks far better.
Old 03-18-2013, 10:13 PM   #3
retfr8flyr's Avatar
I am going to coat the entire floor I am just trying to decide if I need to do a full broadcast or if a medium broadcast of the chips will work.
Earl
Old 03-19-2013, 10:02 AM   #4
Rewards Points: 264
I think you can use however many of the chips you want. I recently epoxied my basement laundry room floor and I didn't want a ton of chips in it, so I just sprinkled as much as I wanted. I had a lot of the chips leftover. It has held up very well thus far. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Old 03-19-2013, 10:50 AM   #5
Newbie Bill
Rewards Points: 518
Do the chips reduce the slipperiness of the floor?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-19-2013, 11:00 AM   #6
retfr8flyr's Avatar
No you need to sprinkle in sand or grit to reduce the slickness. The chips are just for looks, unless you do a full broadcast, then they add to the strength of the covering.
Earl
The Following User Says Thank You to retfr8flyr For This Useful Post:
drtbk4ever (03-19-2013)
Anyone done Quikrete Epoxy Garage Floor Coating Outside on Patio? clevelandrocks Flooring 5 05-11-2011 12:34 PM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 04:41 PM
epoxy coating for waterproof deck Jeremy Hillary Boob, PhD Building & Construction 3 08-27-2010 07:33 AM
Epoxy coating a garage floor? kcrossley2 Building & Construction 2 09-11-2007 02:02 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
