Epoxy Cement Paint On New Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 07:40 AM   #1
Epoxy cement paint on new floor
Looking at putting an EPOXY cement paint down in the new garage. It was pored just this fall and we have not started using it yet due to further construction with the house. do I still need to erch the cement or can I just clean and pressure wash the cement and let dry, then apply paint.
Any brands to stay away from or that you have had good experience with.
drzjoint is offline   Reply With Quote
Old 03-12-2009, 07:45 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
I would recommend taping down a 3x3 foot piece of 6mil poly on the floor. After a few days check it for any moisture under the poly. If there are any moisture issues, you surely don't want to use an epoxy. The vapor pressure will lift it. After that follow the recommendations of the paint manufacturer. Some will like an etched finish on the concrete. All depends on the manufacturer.
Old 03-12-2009, 07:18 PM   #3
thanks.
Old 06-03-2009, 02:05 PM   #4
Quikcrete Epoxy Question
Wondering if anyone knows the answer to this I just did my garage floor this weekend with the epoxy and the paint chips. I went heavy on the chips to make it look like granite, however I did not go heavy enough in some spots. The reason is that I used a base coat spoxy that needed to be tinted, but the guy in lowes said you can use it as is, to make it a cream color backround. However you can see some older stains through it in the concrete. I was just wondering can I actually go over the epoxy with more clear epoxy and ADD more chips.. It has only been 3 days. Will it bond to the current epoxy???
brayden0876 is offline   Reply With Quote
Old 06-03-2009, 04:41 PM   #5
I beleve you can put another coat on but am not sure
Old 06-03-2009, 10:54 PM   #6
Thanks.. I am thinking about it..
Old 06-04-2009, 02:36 PM   #7
You may need to scuff the surface to make it bond. Best is to read the can and see if there is a recoat procedure, or contact the manufacturer and ask them. Most epoxies can be recoated with some prep.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-18-2008 12:32 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 02:04 PM
Cement, plaster, paint - ceiling: "spray skim coat"? BradG Painting 1 11-18-2007 07:06 PM
