Old 10-29-2009, 12:18 AM   #1
Default Engineered wood glue requirement - Very expensive
We got patagonian rosewood engineered floor. The supplier says it has to be glued. His recommened glue is Stuaf960 which is very expensive.
Stuaf 960 has both adhesive and MVP. Do I need MVP ? Is there a way I can do moisture test and go for a regular adhesive available in Homedepot ?
Any one here who glued their engineered wood ? Any thoughts ? Please help !!
cprao is offline   Reply With Quote
Old 10-29-2009, 09:40 AM   #2
Are you glueing to concrete, or wood subfloor? Wood subfloor should not need a moisture barrier. For concrete, I'd duct tape a piece of plastic to the floor for 48 hours & see if you get any moisture. If it's wet when you pull up the plastic, you'll for sure need the MVP
pinwheel45 is offline   Reply With Quote
Old 10-29-2009, 10:45 AM   #3
It is a concrete subfloor. Can you please repeat once again about the moisture test procedure ?
Assume that I don't have a moisture now, is there a chance that it will pop up at the later stage ?
Old 10-29-2009, 11:15 AM   #4
The plastic taped to the floor will draw moisture. As for your other question, it's a good one, but I don't know the answer, maybe someone else will.
I'm getting ready to lay solid, wide plank reclaimed cypress on the concrete slab in the new to us home we just bought. After telling my sells rep what I was doing & getting his advice, I decided to go ahead & use the mvp, to err on the side of caution. My floor passed the moisture test I outlined above, but like you, I'm concerned that I might not get the same results in the future. The extra cost to do the mvp is minimal compared to the value of the flooring, adhesive & my labor to have to tear it out if I have moisture failure down the road.
Old 10-29-2009, 12:17 PM   #5
What kind of MVP you used ? How much it costed you ? Please advise
For me Stuaf 960(recommended by the supplier of wood) is costing me $1375 ( 5 tins of 4 Gallons, each tin is $250 + tax). My wood is costed me $3.7/Sq ft. I have 700 Sq ft to cover. Installer will charge me between 1.75 & 2.00 /Sq ft. I also need to buy rugs to protect the wood where most of the traffic is there. It will cost me minimum $750 bucks.. I am overhelmed with all these growing costs.
Old 10-29-2009, 12:41 PM   #6
I'd have to check my invoice to be sure, but I'm pretty sure the bostichs best & mvp combined was around $1.25/sq ft. Of course, that's my cost as an installer.
Old 10-29-2009, 02:25 PM   #7
Can you confirm the MVP type/grade and the cost incurred by you ? Are you installing the wood yourself or you already installed it ?
Old 10-29-2009, 02:58 PM   #8
1) I saw this Bostick MVP on internet - it is costing around $150.
http://www.lumberliquidators.com/cat...me=product.jsp
This is a 5 gallon tin. Do you know how much area it covers ?
2) This is the Bostic adhesive- Cost of this $100.
http://www.lumberliquidators.com/cat...c_id=CSE_NT_07
Basically, I have 700 Sq ft area.. I am trying to understand how much quantity I need for each one. Please help !!
Old 10-29-2009, 09:01 PM   #9
I'm not sure where my book keeper (wife) filed the invoice. I'll be going to the farm tomorrow, I'll try to look at the buckets to see exactly what I bought.
I'm a hardwood floor contractor by trade. Concrete is outside of my norm, so when I've got a project over concrete, I call my sells rep & tell him what I'm doing & order according to his advice. I'm honestly not 100% sure what he sent me for my project. I'm hoping to get on it within the next couple weeks.
I'm pretty sure he sent me the mvp4 & BST urathane on this page, but couldn't garuntee it. http://www.bostik-us.com/markets/flo...s/default.html
Old 10-30-2009, 01:43 AM   #10
Thank you very much for the information. Based on the documentation, it looks like one Gallon MVP covers 40-45 ft. I think this is $150. This comes in 5 gallon tin. So I would need 4 tins costing me around $700 (Including taxes). Bostic Best Urethane is also costing at $150. I don't know how much it covers.. But I guess I defintely need 4 tins which is again costing me around $700. Then it comes to $1400. If I go for stauf 960, it roughly costs me around 1400.. Both comes to the same number..
So the glue comes around $2/sq ft.
One another question. Why the manufacturer makes it glued ? Is it more stronger than floating wood ?
Old 10-30-2009, 08:05 AM   #11
I'd say your math is pretty close on what you need material wise. My project is around 350 sq ft. I've got 2 buckets of each. I do know, he had cheaper options & ask if that's the way I wanted to go. When I told him I was laying random width solid wood from 6-10" wide, he said go for the good stuff, I garantee it'll hold. So I ponied up the extra coin.
As for you final question, I'm going to have to defer to my other statement, about this being outside my norm. My expertise lies in solid wood over wood subfloors.
Might not hurt to pose your question via email, or phone ( if you can raise anyone) to a couple of glue manufacturers, with details about the product you're laying & laying conditions.
Old 10-30-2009, 11:07 AM   #12
Thank you for all your input.. I will continue to research to see any other viable alternative options to install my wood.
Old 10-30-2009, 08:39 PM   #13
Default Mapei Vs Bostick
I have discovered that Mapei products are also being used as GLUE as well as MVP.
Mapei Ultraband 990 is used for adhesive purposes. I don't know the Mapei brand for MVP.
Does any one has any experience with Mapei products ? How do you guys rate them ? Please advise !!
Old 10-30-2009, 09:26 PM   #14
Wow, that's pretty much a joke-bush league moisture meter. Don't you think if you're spending some real money on a floor, you oughta check the moisture with a little more care and precision?
You can cheaply buy a moisture tester http://americanmoisturetest.com/prod...-test-kit.html
but others are available as well. These will give you a much more quantatative answer than putting plastic on the floor. You are investing a lot in your floor, do it right
Anti-wingnut is offline   Reply With Quote
Old 10-31-2009, 02:56 AM   #15
Gotta love the rude internet. Thanks for your positive, upbeat response.
BTW, the plastic is not to check the moisture content in the floor, but to check for moisture transfer through the concrete through hydraulic pressure.
More On This Topic
Measuring the Gazebo Base
Measuring the Gazebo Base by Expert Village
Hi! Welcome back to Expert Village. My name is Charlie Folkman and today we are going to continue building our gazebo. Now the next step is going to be the construction of our gazebo. Now the first thing that we want to do is create the octagon shape of... Read More »
16mm Films: Storage
16mm Films: Storage by Expert Village
Hi! I’m Grady Johnson with Karma Train Productions and today we are discussing 16 mm films and I’m representing Expert Village.com. Well, I really enjoyed that film; one of my favorites. This is a historical film and it came with a pretty... Read More »
Since we've used glue on the inside of the turtle you want to make sure that stays nice and firm. So one of the ways to do that is to connect a couple of pipe cleaners depending on the size of your turtle. If it's a little smaller you could probably get... Read More »
There is no reason to throw out a chair because of a loose chair rung. Fixing a loose chair rung is quick and easy to do. It is a great skill that allows you to fix flea market finds and garage sale cast-offs, or just to prolong the life of your existing... Read More »
With rising fuel costs and the desire to heat with renewable energy sources more people are turning to wood pellet stoves. Pellet stoves burn small wood pellets which are made from sawdust that would otherwise be put into landfills. Sawdust decomposes... Read More »
Nailing down engineered wood planks ? Flt_Simulation Flooring 2 05-14-2009 06:36 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 06:30 AM
What to install under engineered wood floors renfrey Flooring 2 11-26-2008 10:26 AM
How much more expensive is to build home from brick/steel/concrete instead of wood? Nuieve Building & Construction 5 09-17-2007 10:46 PM
Where to buy adhesive for engineered wood floor SoConfused! Flooring 2 12-04-2006 11:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
