Engineered Wood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 07:06 AM   #1
Rewards Points: 154
Engineered wood floors
I was told that factory finished floors are more durable and resistant to daily use as compared to traditional sanded stained and polyurathaned flooring, true ? or ????
also, someone said you can use oooo steel wool and paste wax on wood, would car wax work in this case or no. thanks, G
turbomangt is offline   Reply With Quote
Old 05-07-2010, 04:50 PM   #2
WHOA
lol You've got some interesting questions there G.
The argument there is that the better factory finishes are uv cured which basically allows them to dry faster and allows for more coats of finish to be applied. I have, however, seen some sand and coat floors that looked as good for as long as their prefinished cousins.
You should only use wax on a wax finished floor. I don't know if car wax would work, don't know anyone that has ever tried it lol My advice would be to not use car wax on a floor (because of the various chemicals that may not be appropriate.)
Good luck!
rcuerrier is offline   Reply With Quote
Old 05-07-2010, 07:12 PM   #3
Rewards Points: 154
I as told in a previous post that I should use 0000steel wool and wax for areas that are scratched, this is the same area I have a toddler crawling around, are you saying I should not use wax? or is their a special kind that is non toxic??????????????????
Old 06-28-2010, 05:46 AM   #4
Use hardwaxoil!
Hi there,
I have a prefinished engineered hardwood floor myself. Key to your question is: what type of finish is used for your floor?
A UV-varnished floor cannot be maintained or repaired locally. In those cases you would have to sand the whole floor down and finish it again. For that reason I'm fond (and still very satisfied!) of hardwaxoil. My floor is finished with a hardwaxoil that is applied in a single coat and can be maintained locally, without any colour overlap, and consists for 100% of natural ingredients.
Hope this migth help you out?
Steven78 is offline   Reply With Quote
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
Engineered wood failed under refridgerator BlueBSH Flooring 15 11-20-2009 11:13 AM
Foam underlayment for engineered wood tired_and_crazy Flooring 2 06-12-2009 01:27 PM
Between coats of polyurethane on wood floors, how do you get up the dust? proofer Painting 1 04-07-2008 07:27 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 11:03 AM
