Engineered Wood Floor Removal? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 05:34 PM   #1
We are getting ready to replace the old carpet in our living room and the 20-year old, glued down engineered wood in our dining room. The two rooms flow into each other and we plan to lay laminate in both areas. I've gotten a couple of estimates and it seems like we have two options:
1. Rip up the engineered wood, which could be costly, difficult and potentially damage the plywood subfloor underneath.
2. Raise the height of the subfloor under the carpet to match the engineered wood and lay laminate over top of it all.
We are on a budget but want to be sure we make the best choice. Any thoughts would be greatly appreciated!
Bottlerocket is offline   Reply With Quote
Old 02-19-2013, 07:02 PM   #2
Rewards Points: 13,690
Highly unlikly it's glued down engineered flooring since it's a fairly new product.
Nothing lowers the value of a home faster the laminite flooring.
If that's all you can efford and you plan on staying in the home for a while go for it.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
SFI Engineered Wood Floors Selectingafloor Flooring 0 03-13-2012 03:37 PM
Laminate vs Hard wood vs Engineered?? Gecko Flooring 1 02-22-2012 06:35 AM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 08:59 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
