Old 02-17-2010, 03:18 PM   #1
engineered wood floor on radiant heating
Here are a few questions for those on this site that have lots of knowledge:
1) What substance do you use to make a concrete floor level? i.e. fill in dips
2) A particular 3/8" Bruce floor suggests a particular underlayment that is only 0.075 inches thick. Can I use something thicker? Can it be a different brand? Or is it best to stick with the same company? Will 0.075 inches give enough cushion for the floor?
3) For a transition piece at a doorway that butts up to tile, what is the best piece to use? Can the floor be butted up directly to the tile (with metal edging already in place)? or do you really need to have a space for expansion in the 3 foot doorway?
Thanks ahead of time!
hikergirl99 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Nailing down engineered wood planks ? Flt_Simulation Flooring 2 05-14-2009 05:36 PM
engineered wood flooring flugalbinder Flooring 1 05-06-2009 11:51 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
