engineered wood floor not glued down - need suggestions
looking for some advice on re-gluing engineered wood floors....I had installed engineered wood floors by glueing them down to the concrete slab floor....however, the installation was not successful and parts of the floor are not glued down....this results in a popping sound and excessive flex when a person steps on the bad spots
How can I fix this? I don't want to put in screws but don't know how to get the floors to stick now that they are already installed? I have heard there is a kit where a tiny hole can be drilled in the floor boards, glue injected via syringe and then lead weights used to secure the floor? has anyone tried this technique and can you point me in the right direction for the require products?
