Engineered Wood On A Floor In A Cabin - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 07:50 PM   #1
Engineered wood on a floor in a cabin
I would like your help/opinion on this: I have a lake cabin that I want to use carpet and engineered wood on the floors. Since it is at the lake, I do have sand that comes in when people come into the cabin. Even though they brush their feet, sand still gets in.
Mistake or should be ok? The wooded area will be at an entry way from the lake and in the kitchen/bathroom area.
javadiva is offline   Reply With Quote
Old 01-23-2012, 08:10 PM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Should be ok with that... If there's room widen the wood floor area so there's a definate good spot to remove shoes and leave beside the door
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
The Following User Says Thank You to Tech Dawg For This Useful Post:
javadiva (01-23-2012)
Old 01-23-2012, 08:12 PM   #3
Rewards Points: 13,732
I'd never warrenty that job. #1 a wood floor in a bathroom is not a great idea, and knowing there's gong to be sand on it being ground in may be a maintaince issue.
Any chance you would concider sheet linolium?
My dad has a house on the lake and took out all the carpet long ago because my mother had to vacuum 3 times a day. He went with linouium and it's been down for a good 20 years and still looks fine and that's with 11 grandchildren and hundreds of guest over the years. Spill a drink, wipe it up, run the broom around once a day and it's cean enough.
Old 01-23-2012, 08:15 PM   #4
Tech Dawg's Avatar
Sorry, missed the bathroom part..... Vinyl would be a better choice for the bathroom
Todd
www.aloneeagle.com
Old 01-24-2012, 02:19 AM   #5
What is involved in putting sheet vinyl down?
How will hold up in cold environment?
At this point I have the osb sub floor.
What would I need to put down over the sub floor?
Hardway is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 08:59 AM
engineered wood floor for kitchen Isabelbr Flooring 2 01-17-2011 06:12 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 10:13 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
