Engineered Wood Floor Buckling - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 06:26 AM   #1
Engineered wood floor buckling
Recently a friend of mine had a wood floor (click) and it is buckling. The wood was acclimated for a week and a moisture barrier was used. However, there are several areas along the perimeter that are laid right up against the wall and I believe this may be the problem. What tool is available to cut a 1/4-3/8" gap from the wall with a plunge depth of 3/8"?
Thanks for the help in advance
Telecorp is offline   Reply With Quote
Old 01-25-2012, 07:00 AM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Might need a MultiMaster..
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
The Following User Says Thank You to Tech Dawg For This Useful Post:
oh'mike (01-25-2012)
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 08:59 AM
engineered wood floor for kitchen Isabelbr Flooring 2 01-17-2011 06:12 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 10:13 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
