Engineered Wood - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 10:25 PM   #1
Rewards Points: 264
engineered wood
Planning on using Waverly engineered flooring in pine. 1/2" X 2 1/4" strips are in my budget, though I would prefer something a little wider. Going to have this floated, but the edges are t and g for glue.
Anyway, here is the question-What is the best under layment material? The slab is not real flat, lots of bumps and waves to work out.
Any comments are appreciated!
7echo is offline   Reply With Quote
Old 11-22-2008, 06:06 AM   #2
Foam underlayment works well. Make sure the surface is flat before you put the flooring down. Use black felt paper under the underlayment first to make the surface level. Cut ovals and stack them in ever smaller shapes like a topography map. This will give you a level surface and then put your foam underlayment and then your floor. Use a long straight edge to check for flat.
Good luck
designstate is offline   Reply With Quote
Old 11-22-2008, 11:31 AM   #3
Get out of the box!
Rewards Points: 260
Are you sure you can float something that thin?
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 11-22-2008, 04:27 PM   #4
Rewards Points: 264
designstate-
The floor guy said they would float out the floor instead of build up with felt, and maybe have to grind a few high spots.
26 years-
Mfg says it can be glued down, stapled, or floated. I think I have seen other brands with 1/2" that say floating is OK. What would your concerns be? Don't want a mistake and end up with a mess. The 2 1/4" x 1/2" is affordable for us, and the installer is a big costumer of the flooring mfg and backing up his labor. I know him from work and feel like he will make things right.
Thanks for your comments!
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Engineered Wood question LaurynJohnny Flooring 1 01-21-2008 11:32 AM
