Old 07-27-2010, 10:54 AM   #1
engineered hardwood over regular plywood
Hello,
I am in the process of preparing my subfloor for the installation of engineered hardwood. My home was built in the 1940's and has an existing subfloor that consists of 3/4" t&g boards installed on 16" OC floor joists. The subfloor is in good condition but I would like to stiffen and level it by covering it with a layer of plywood. The lumber store has high quality underlayment available but I feel that regular plywood would be adequate in my case. Do I need the sanded/clear underlayment for engineered hardwood or would regular 1/2" ply be ok (glued and screwed)?
Thanks a bunch,
John
jcomp is offline   Reply With Quote
Old 07-27-2010, 11:23 AM   #2
Handyman
If the existing floor is in good condition why not just screw it down to within an inch of it life? The added plywood may cause you grief with the additional height.
canadaclub is offline   Reply With Quote
Old 07-27-2010, 12:29 PM   #3
Thanks for reply. In my opinion there is too much deflection in existing subfloor and it is not flat enough. The plywood should solve these issues- no concern of floor height- gutted entire first floor of home.
Old 07-27-2010, 01:45 PM   #4
Handyman
In that case, lay away. You still should screw the new floor down though
Old 07-27-2010, 03:00 PM   #5
Moderator
http://www.fcimag.com/CDA/Archives/B...00000000141280
http://www.apawood.org/pablog/index....-Floor-Systems
Be safe, Gary
Clothes taking longer to dry?
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 09:45 AM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 01:05 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
