Engineered Hardwood Over Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 07:13 PM   #1
engineered hardwood over concrete slab
I have a couple of questions-
I have a concrete slab at grade that used to have asbestos tiles on it. Tiles are gone but black mastic (cutback adhesive remains 5% asbestos). I am thinking about encapsulating it with a product like ARDEX SD-F. I also understand that this will level out the floors if needed. I do have some divots caused be removing nails from old carpet tack strip.
Does ardex cause any bonding issues with urethane glue for the wood floors?
I have also heard of people using bean-a-doo to remove the mastic and cleaning with a degreaser and then gluing hardwood directly to slab.
Has anyone done that before - how easy is bean-a-doo to work with? Looks messy but fairly quick.
BSCHO is offline   Reply With Quote
Old 02-01-2011, 07:52 PM   #2
IS the engineered wood snap lock too or not? IF it is snaplock you can run it as floating too. IF you insist on gluing that glue will hold to just about anything. I have never used bean-a-doo so I can't comment on how good it works.
proremodel is offline   Reply With Quote
Old 02-01-2011, 07:55 PM   #3
Experienced
Jackofall1's Avatar
Without a whole lot of preparation putting wood on a concrete slab is not recommended. You will really need a floating subfloor, with a ton of vapor stop between the floating subfloor and the concrete.
Mark
Old 02-01-2011, 10:56 PM   #4
Rewards Points: 164
Don't the enginered floors have a closed cell foam underlayment? I think that would be the way to go.
KarlJay is offline   Reply With Quote
Old 02-01-2011, 11:00 PM   #5
Some due- I have done a few snap lock engineered floors right onto concrete. I just lay the pad tape the seams and go to town. Have not had a problem yet.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Hardwood sleeper floor on slab acerunner Flooring 4 08-24-2010 11:47 PM
Help on tool selection for leveling concrete slab Wohn Flooring 3 07-11-2010 03:03 AM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 10:35 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
