Engineered Hardwood Installation; Floating Or Glue? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2007, 12:21 PM   #1
Rewards Points: 50
engineered hardwood installation; Floating or Glue?
OK, I want to install 3"x9/16" engineered hardwood over new concrete slab. This particular supplier recomends the floating system using a foam underlayment. Wood glue is used only between the tongue and grooves. Assuming my slab is dry and level, do any of you experts see a problem with this method? I ask because some manufacturers say "float", others say "glue". Is it just a personal choice? Thanks for your insight! El Buey
El Buey is offline   Reply With Quote
Old 08-17-2007, 12:30 PM   #2
I think float is the way to go... have it done that way for my previous condo... and it works well...
KUIPORNG is offline   Reply With Quote
Old 08-17-2007, 12:48 PM   #3
Rewards Points: 50
How I love a positive response. Did your installation go smoothly? Are you a professional? I'm not.
Old 08-17-2007, 03:32 PM   #4
at the time it was done... I hire contractor ... if I have to do it again now... I would do it myself... the trick is really appling the glue to the tonque and groove I would think... as you want just righat amount ... too much it spill and make the surface looks ugly... too little it doesn't bond well... but with some practice,... I am sure it can be handled... I did my basement with laminate and find it so...o...oo..... easy... but that doesn't require and glue at all...
Old 08-17-2007, 03:53 PM   #5
Rewards Points: 50
Thanks, I'm still feeling positive. By the way, for anyone reading this, there is a ton of information on this subject (including installation instructions) at www.hardwoodinstaller.com/hardwoodinstaller/floater.htm. El Buey
Glue and staple hardwood? jdoherty Flooring 2 06-06-2007 10:38 PM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 09:37 AM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 10:06 AM
engineered hardwood wildeman Flooring 2 10-14-2006 01:24 AM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 10:03 AM
