-   -   engineered hardwood installation; Floating or Glue? (http://www.diychatroom.com/f5/engineered-hardwood-installation-floating-glue-10800/)
El Buey 08-17-2007 11:21 AM
OK, I want to install 3"x9/16" engineered hardwood over new concrete slab. This particular supplier recomends the floating system using a foam underlayment. Wood glue is used only between the tongue and grooves. Assuming my slab is dry and level, do any of you experts see a problem with this method? I ask because some manufacturers say "float", others say "glue". Is it just a personal choice? Thanks for your insight! El Buey
KUIPORNG 08-17-2007 11:30 AM
I think float is the way to go... have it done that way for my previous condo... and it works well...
El Buey 08-17-2007 11:48 AM
How I love a positive response. Did your installation go smoothly? Are you a professional? I'm not.
KUIPORNG 08-17-2007 02:32 PM
at the time it was done... I hire contractor ... if I have to do it again now... I would do it myself... the trick is really appling the glue to the tonque and groove I would think... as you want just righat amount ... too much it spill and make the surface looks ugly... too little it doesn't bond well... but with some practice,... I am sure it can be handled... I did my basement with laminate and find it so...o...oo..... easy... but that doesn't require and glue at all...
El Buey 08-17-2007 02:53 PM
Thanks, I'm still feeling positive. By the way, for anyone reading this, there is a ton of information on this subject (including installation instructions) at www.hardwoodinstaller.com/hardwoodinstaller/floater.htm. El Buey
