Engineered Hardwood On Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 10:43 AM   #1
bryanp22's Avatar
Rewards Points: 288
We are finishing our basement and are looking at flooring options. Carpet is out so its either painting the floor and use rugs or an engineered hardwood. The floor is uneven though so painting would obviously be cheaper and easier, but want to examine all options. Has anyone used dricore? They sell it at Home Depot and that is what they recommended and they sell shims for uneven floors too. Looks like it just floats above the concrete though. Is that the best option?
bryanp22 is online now   Reply With Quote
Old 04-28-2013, 01:06 PM   #2
I havent heard bad things about it but it is expensive. It also acts as a moisture barrier.They also recommend to install 3/8th plywood over it.
k20vteck20 is offline   Reply With Quote
Old 04-28-2013, 01:24 PM   #3
bryanp22's Avatar
Rewards Points: 288
What else could I do that would be cheaper? Not sure what options are really to out engineered wood floor on concrete.
Old 04-28-2013, 01:38 PM   #4
You can use a 6mil plastic sheathing and a foam pad for flooring then get a engineered wood that has a click and lock system. Before your prep if you floor isn't level you might want to even out your floor with some self leveling compound.
water spill into the living room (hardwood floor) and it leaking into the basement. miyervang Flooring 2 02-20-2013 01:01 PM
Need suggestions for Hardwood floor, engineered Lock and Fold? MANswers Flooring 2 09-28-2011 07:41 PM
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 07:32 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 06:24 PM
Moving basement washer to first floor issues mazeroth Plumbing 2 02-05-2011 10:10 AM
