Engineered Hardwood Around A Bannister - Flooring - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 09:06 PM   #1
engineered hardwood around a bannister
The bannister is attached to the sub floor as it was carpeted before. Can we cut the bannisters and slide the engineered under?
rickone is offline   Reply With Quote
Old 06-02-2010, 11:12 AM   #2
Handyman
Rewards Points: 512
Depending on the way the newells were installed, yes you can. You can detach them from the top rail and they will either pull out or unscrew from the floor. Drill holes in the new flooring to reseat them but make the holes 1/4 in larger to allow for 'floating'
canadaclub is offline   Reply With Quote
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 12:09 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
Quality of Pergo engineered HARDWOOD? Jeff12 Flooring 2 01-13-2008 10:17 PM
