Engineered Flooring, Will It Settle???? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2008, 12:43 PM   #1
Engineered flooring, will it settle????
I just installed engineered flooring, left the proper gaps around the edges...there is some sections that seem to bubble quite a bit, it's a 120 year old house so I didn't expect it to lay perfectly flat, but will the hardwood settle and contour around the humps and dips of the floor (no major humps or bumps)? I'm assuming once I get the furniture in and we walk on it on a regular basis it'll settle a bit and some of the bounce will be taken out. anyone have exprience with how much an engineered hardwood floor will settle?
rdmccaw is offline   Reply With Quote
Old 04-14-2008, 05:50 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Engineered flooring isn't known to "settle" on its own beyond what gravity does to it and the weight of furniture. It also has explicit installation requirements and minimum requirements in substrate plane.
If the substrate isn't within the recommended guidelines of the manufacturer the floor could wreck itself. How was it installed? Is this a floating floor?
Old 04-14-2008, 06:41 PM   #3
Rewards Points: 150
Buds right, it sounds to me like your trying to bend the floor a little more than you should.
After a while your gonna see seperation and delamination if you dont address the uneven subfloor
mike costello is offline   Reply With Quote
Old 04-15-2008, 12:19 AM   #4
Boz
Gus
Boz's Avatar
No...
Boz is offline   Reply With Quote
Old 04-15-2008, 07:29 AM   #5
I was hoping for a little bit more of a positive response... I think it is bubbleing as a result of the boards not being put in as tight as they should be...It's happening where I started and I wasn't tapping the boards in as I layed them, figured that out after the fact and the rest of the floor, where I tapped is fine... It's a floating floor, I was thinking that over time, with some weight on the floor they may tighten themselves up, I don't think it's so much that the floor is uneven, although it is a bit!
Old 04-15-2008, 07:41 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I was thinking that over time, with some weight on the floor they may tighten themselves up...
Based on that line of thinking...then a flat tire will over time repair itself and gain new air.
Old 04-16-2008, 08:10 AM   #7
That doesn't make any sense, lets get a little bit better of an analogy... foundations around home crack, because gravity causes homes to "settle", as in move towards the center of the earth! So, I was hoping that the hardwood may "settle", as in gravity pulling them towards the center of the earth! I didn't follow the air in the tire idea
Old 04-16-2008, 04:31 PM   #8
Rewards Points: 150
Well think about it. The floor is held together with a pretty fragile tongue and groove, if you start stressing that by bowing the flooor those will snap and you will get seperation.
Also if your bending a laminated product you run the risk of delamination as well.
Fact is there are grade tolerances for a reason and the should be adhered to for a floating floor to last
TrafficMaster Engineered Wood Flooring in Basement Vermonster Flooring 4 04-02-2008 11:23 AM
Engineered Flooring Install Question funktional Flooring 2 01-04-2008 03:45 PM
engineered flooring - advice please colbard Flooring 2 10-28-2007 10:25 PM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 01:30 PM
