Engineered Flooring Over Oak Strip Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 07:42 PM   #1
Rewards Points: 340
engineered flooring over oak strip flooring
I want to install some 2 1/4'' prefinished engineered(3/8'') flooring over my solid oak strip flooring.The original oak is has no subfloor under it. It is nailed to the joist which are 16'' o.c.
Do I glue it down or rent a stapler to install it.
kt82 is offline   Reply With Quote
Old 02-28-2012, 07:49 PM   #2
Rewards Points: 13,712
I can see some issue by doing that. If I was you I would be contacting the manufacturer of the new flooring. No matter what we say when it comes to warrenty they have the last say.
I never would glue it down. I've seen to may fail.
Is there a vaper barrier under the floor on the ground?
Why not just refinish what you have and add insulation under it?
Old 02-28-2012, 08:26 PM   #3
Rewards Points: 340
I just finished reading the NWFA guidines.It's a wonder woodfloors were ever installed.
I am going to install some A/C plywood over the oak flooring and staple the engineered over that .
I would refinish ,but it is a 100 year old floor that has many bad spots
thanks for your reply
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Glue down engineered wood flooring mh8888 Flooring 9 03-06-2011 06:30 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
engineered wood flooring flugalbinder Flooring 1 05-06-2009 10:51 AM
Engineered Flooring Doorway Transitions? GaryD Flooring 1 12-21-2007 05:06 PM
