Old 03-29-2007, 01:00 PM   #1
Default Engineered Flooring in Kitchen
HI, I have a new construction project and I have above grade concrete slab on the first floor. Will have someone install the flooring(vapor barrier, foam underlayment, floating floor).
I will go with engineered wood flooring on the first floor and I was advised to put down 3/4" plywood underneath the kitchen cabinets.
I am using a concrete sealer to take out any moisture issues underneath the cabinets and leveling out the concrete slab which isn't too bad.
My question is:
Should I leave out the plywood "subfloor" for the stove and dishwasher for the floor guy to install the floating wood flooring in those areas? I am only concerned that the plywood might show through when the finished flooring is complete. Or maybe I cut in 3 inches to eliminate that issue?
I have mocked up the base cabinets over the plywood to make sure that it doesnt extend over the kick boards of the cabinets.
Thanks! Rod
Hages is offline   Reply With Quote
Old 03-29-2007, 03:30 PM   #2
Master Craftsman
Big Dave's Avatar
I would leave out the plywood for the dishwasher area and stove area. It will just look better and cause less issues down the road it there is flooring in those areas.
I would however go with a plywood subfloor that is the same thickness as your flooring. If it's a full 3/4 engineered flooring then by all means go with the 3/4 underlayment if it's only 1/2 inch flooring then drop back to 1/2 inch underlayment.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
More On This Topic
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Hi I'm Betty Ingham and speaking on behalf of Expert Village and I would like to give you a little information on decorating a Victorian kitchen. One of the neat things about restoring an old Victorian house is you can do it the way you want to we wanted... Read More »
Hi, my name is Kevin and on behalf of Expert Village, I'm going to talk a little bit today about woodworking. When you're woodworking for your home or for a project that you're doing for your business, one of the main things you have to decide is whether... Read More »
Whether you are remodeling an old kitchen or designing a new kitchen for a new home, functionality is the key to kitchen design. Having a functional layout in the kitchen not only makes the kitchen more inviting to your family and guests, but it also... Read More »
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 04:20 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 04:38 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 05:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-19-2006 12:23 AM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 11:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
