Engineered Flooring Doorway Transitions? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-19-2007, 08:31 PM   #1
I am laying 4 1/2" x 3/4" engineered hardwood plank flooring (Capella) on 3/4" T&G plywood and I am confused about doorway transitions. I have a hallway with two bedrooms off one side and a single master bedroom off the other and a tiled bathroom. The master bedroom is 18' x 13'. The other bedrooms are on the order of 11'x13' It is clear to me that I need reducer or T molding for the transition from the tile to the wood, but it is not clear whether I can avoid using T molding between the bedrooms and hallway. Avoiding the T molding would make the hall and bedroom areas look less fragmented and possibly reduce trip hazards. The planks in all rooms will run the same direction down the length of the hallway (perpendicular to the joists) and parallel to the door openings. Can I get away with not putting in T molding in the doorways or am I asking for trouble? What are the pros and cons? Thanks.
GaryD is offline   Reply With Quote
Old 12-21-2007, 05:06 PM   #2
Floorwizard's Avatar
Only a nailed floor can be installed without transitions.
if you float it, then it needs the expansion spaces.
It is recommended to use t molding in doorways that will have the same wood.
if the bedrooms have carpet, then you will need an end cap.
Floorwizard is offline   Reply With Quote
engineered flooring - advice please colbard Flooring 2 10-28-2007 10:25 PM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 01:30 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 09:03 AM
