Engineered Click Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 11:22 AM   #1
Engineered click over concrete
I purchased the Home legends 3/8 x4 engineered click hardwood flooring with a 55 year warranty. Any one have any experience with this floor? Trying to find a vapor barrier that doesnt void warranty and it was very specific. This was the requirement:
"non-recycled (100% virgin resin) 6-mil. Polyethylene film vapor barrier with a density of .92 lbs./cubic ft. and a thickness tolerance of +/- 10% is installed over the concrete subfloor that emits a water vapor no greater than 5 lbs. per 1000 sq. ft. within 24 hours."
I dont have a lot of faith in warranties, but i do want to make sure it is installed correctly and the vapor barrier the store ordered voids the warranty b/c it contained 15% recycled material. What type of vapor barrier would be best, but also what type of cushion? It is only 3/8 on core board. Would like floors to feel like hardwood and have some cushion to them if possible. The store is installing 1200 sq ft on ground floor with concrete subfloor as a part of a $400 whole house installation special and will also be doing the stairs. How does click floor install on stairs? We ordered the stairnose, but i am talking about the floating aspect.
details is offline   Reply With Quote
Old 11-10-2011, 08:41 PM   #2
Look for a product called Silencer. Vapor barrier is already attached. You can not install steps in a floating method. Be sure steps are installed with urethane adhesive. Stairnose too. Urethane adhesive is powerful stuff.
plowboy is offline   Reply With Quote
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Best underlayment for Engineered hardwood on concrete jcieutat Flooring 0 11-28-2009 04:14 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 02:16 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
