Engineered Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 09:58 AM   #1
Rewards Points: 264
engineered adhesive
What is the best adhesive if I can't get all the cut back removed? Will the high solids urethane adhesive from Mapei or Bostiks work OK? Any special prep work I can do to help ensure good adhesion? Some of the cut back is really stuck to the slab. Putting down 5" x 1/2 engineered flooring.
7echo is offline   Reply With Quote
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
engineered wood flooring adhesives moejoe Flooring 1 07-21-2010 11:26 PM
Cleaning adhesive off poly coated engineered wood sportinwla Flooring 6 02-05-2010 08:35 AM
Where to buy adhesive for engineered wood floor SoConfused! Flooring 2 12-04-2006 10:21 PM
