Eng H/W Install - Foam Or Felt Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 01:25 PM   #1
raylo32's Avatar
Rewards Points: 1,244
Eng H/W install - foam or felt underlayment?
Getting ready to do a Mannington engineered hardwood install... will be "floating" on an at-grade concrete slab. I have seen two types of "premium" underlayments that both have the requisite vapor barrier for moisture protection. Lowes has one that has a felt-like or fibrous mat layer, while Home Depot has Roberts 3 in 1 foam underlayment. Both are similar price ($50-60 US), have the vapor barrier, and are good for 100 sqft. The foam rolls are about 1/3 the size of the felt type since the material is thinner. Home depot also had some much cheaper foamlike products that I have not researched or considered.
Is there an advantage to one type over the other in this type of install? Mannington seems to sell their own version that looks more like the Roberts foam type as far as I can tell from online info.
raylo32 is offline   Reply With Quote
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 12:26 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
Help for Tile install. Cork underlayment? andy1908 Flooring 8 06-04-2009 03:54 PM
Estimated time to Install Underlayment lucknowm Flooring 5 03-06-2008 07:26 PM
