Old 11-21-2008, 12:05 PM   #1
Encapsulating old asbestos vinyl tile
Any comments on my idea please ?
Concrete slab - 40 year old 9x9 asbestos vinyl tile on top of slab. Slight odor comming from hydrostatic pressure wicking up some moisture and moistening the old adheasive (cut back)? I want to put down padding and carpet (grade level family room). Can I put another layer of tile over this old tile to encapsulate it ( stick on 12x12 or even sheet vinyl?). Or is dry-lock /sealer or epoxy coating a better idea? Or..just paading and carpeting over the 9x9 tile?
Paul
Familypro40 is offline   Reply With Quote
Old 11-21-2008, 08:48 PM   #2
jamiedolan's Avatar
Paul
Why not just remove the old tiles? It's not a big deal.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-21-2008, 09:56 PM   #3
Jamie
Jamie,
after reading all the warnings on this site I am a bit afraid to as the room is 240 sq.ft. I would like to be rid of it though. Any new thoughts on removal of the old tile and adhesive?
Thanks.
Paul
Old 11-22-2008, 12:11 AM   #4
Get out of the box!
Jamie
It might be wise to stop suggesting people remove asbestos laden tile man.
And certainly a slab issue that is reactivating the cut back.
There are still lawsuits pending on asbestos issues.
I would have it professionally abated or just overlay/escapulate it with ditra.
26yrsinflooring is offline   Reply With Quote
Old 11-22-2008, 07:03 AM   #5
Have it removed professionally. I had someone do my whole slab house when I bought it. My house was about 1000 square feet and the whole removal cost about 1500.00 While not cheap it is cheaper than the fine you can get for dumping asbestos illegally. That fine can be over 10K. Plus if the tiles break than that means you are breathing asbestos dust. Not too healthy. Just get rid of them. I feel so much better knowing that there is no asbestos under foot.
designstate is offline   Reply With Quote
Old 11-22-2008, 12:35 PM   #6
Get out of the box!
Design.
This is nofriable asbestoes so the only way to reactivate the it is to sand it or bust it up into little tiny peices then breathe the dust in.
It is the lowest form of asbestos ever introduced into the market.
But
It is till to our best interest not to advise that any home owners do it them selves.
Old 11-22-2008, 02:26 PM   #7
Very true about it being the safest form of asbestos. In my house when I bought it I ripped up the carpet and almost every tile was cracked to heck. Also, as they age they become brittle. So if he wanted to remove them than they will probably break. That would be when the asbestos becomes airborne. Sure not as much as if he were to grind, cut, or saw it but it still becomes airborne. Also, you can't just remove it yourself. It is very illegal to do so unless you are a professional. This is what I found out when I had to take care of my floors.
Old 11-22-2008, 04:15 PM   #8
FamilyPro40:
What condition is the floor in. You say there is moisture coming up through the concrete basement floor. Normally, one would expect that this would cause the floor tiles to pop loose because of the water pressure or water vapour pressure pushing up on the tiles.
If the tiles are in good shape, then I'm questioning the source of the odor you claim is in the basement. Maybe that odor is a dried up p-trap at the bottom of your basement catch basin (also called a "floor drain") that may be allowing sewer gas to come into the basement. Alternatively, since the weeping tiles around your house drain into either a catch basin or sump pit in your basement, if you haven't had rain for a while, a "musty" smell could be coming from the pipes leading to those weeping tiles.
Are there any loose tiles on your floor?
It's just kinda hard for me to reconcile the notion that there's enough water coming up through the concrete to cause the basement to smell with the notion that the floor is in good enough shape that you're thinking of just putting a new flooring material over it. One of those two pictures has to be wrong.
Nestor_Kelebay is offline   Reply With Quote
Old 11-22-2008, 10:38 PM   #9
jamiedolan's Avatar
Jamie,
Thanks.
Paul
Many times safe removal of old flooring that may contain asbestos has been discussed here. I've removed it a number of times. Some basic safety precautions are in order, but I personally don't belive that asbestos floors tiles are generally the hazard they are made out to be.
The State of Minnesota Department of Health give out directions for home owners who want to remove tiles themselves.
http://www.health.state.mn.us/divs/e...ndex.html#rcan
Jamie
Old 11-22-2008, 10:40 PM   #10
jamiedolan's Avatar
Originally Posted by 26yrsinflooring View Post
Jamie
Perhaps there is more danger to this than I am aware of? The Minnesoata Department of Public Health for example gives directions to the general public on their web site for people that wish to remove asbestos laben products:
Jamie
Old 11-22-2008, 11:58 PM   #11
I tend to agree with Jamie. While asbestos related lung diseases is on the rise in the general population, MOST of the documented cases of mesothelioma are from people who were exposed to high concentrations of asbestos on a regular basis for many years as part of their jobs.
The following web site:
http://www.healthzone.ca/health/article/476199
says the chances of developing an asbestos related disease depend on the size and concentration of the asbestos fibers inhaled and the length and frequency of exposure to airborne asbestos fibers. That says that occasional exposure to relatively low concentrations of asbestos fibers (as in removing vinyl tiles that contain asbestos, being somewhat of a "one-time" exposure is much less likely to result in an asbestos related disease than regular, frequent and prolonged exposure that might be incurred on a job.
This web site:
http://www.asbestos.com/exposure/
says:
"Although statistics have shown a growing number of individuals who have never worked with asbestos are suffering with asbestos-related illness, most documented cases of such diseases are caused by occupational exposure.
This is due to the likeliness of repeated exposure, which occurs through standard operations in a variety of industries and jobsites.
Naturally, jobsites such as asbestos mines, processing plants, and manufacturing plants where asbestos products were made have a legacy of high occupational exposure. But many other jobsites, such as oil refineries, power plants, and chemical plants, share a history of asbestos exposure as well."
So, even though we don't know who's susceptible to asbestos related diseases and who isn't until those diseases show up in the individual, the liklihood of contracting a disease from exposure to asbestos is heavily dependant on the frequency and duration of exposure which is typical of people exposed to asbestos on their job.
Also, asbestos was used in so many products prior to 1980, that it's hard to imagine anyone not being exposed to asbestos that lives in a house built prior to 1980. And yet, people that live in those houses don't all die of asbestos related diseases. Here's a list of all the products that were likely to contain more than 1 percent asbestos prior to 1980:
http://www.asbestos.com/products/
Note that baby powder, automotive brakes, cigarette filters, and drywall joint compound are on the list. That means that any mother or baby that used baby powder, every one that ever took their car in to have the brakes checked or replaced the shoes/pads themselves, every smoker, and anyone that ever sanded down a drywall joint prior to 1980 was exposed to airborne asbestos dust. That probably includes 95 percent of the population in 1980. And yet, now, AT LEAST 28 years later, we're all not kicking over from asbestos related diseases.
Old 11-23-2008, 12:06 AM   #12
jamiedolan's Avatar
Originally Posted by Nestor_Kelebay View Post
I tend to agree with Jamie. While asbestos related lung diseases is on the rise in the general population, MOST of the documented cases of mesothelioma are from people who were exposed to high concentrations of asbestos on a regular basis for many years as part of their jobs. Also, asbestos was used in so many products prior to 1980, that it's hard to imagine anyone not being exposed to asbestos that lives in a house built prior to 1980. And yet, people that live in those houses don't all die of asbestos related diseases.
says the chances of developing an asbestos related disease depend on the size and concentration of the asbestos fibers inhaled and the length and frequency of exposure to airborne asbestos fibers. That says that people that do a renovation in their home are not nearly as likely to be affected by asbestos related diseases as people who work with asbestos for a living.
This web site:
says:
So, even though we don't know who's susceptible to asbestos related diseases and who isn't until those diseases show up in the individual, it seems clear that regular and prolonged exposure to airborne asbestos is what's needed to contract an asbestos related disease.
Someone being exposed to even high levels of airborne asbestos fibers doing a renovation in their home isn't as likely to contract an asbestos related disease as someone who is regularily exposed to it on their job.
Even if the asbetos fibers are a concern, doesn't wearing a $30 respirator and weting down the tiles almost completely mitigate the risk?
It seems to me that asbetos exposure is just like x-ray exposure. We consinder a few xrays pretty harmless, however, it is considered harmful for a xray tech to get exposed to xrays day in and day out. Maybe we will learn something new in the future about asbestos that shows us it is more harmful than we think it is now. But I'd be willing to bet that there is far more danger with many other things than a one time asbestos removal. Just an opinion, but I bet mroe people harm themselves or others with DIY electrical than asbestos... again, just an opinion.
All that said... Remove asbestos at your own risk, whatever you deem that risk to be...
Jamie
Old 03-22-2009, 04:04 AM   #13
jbk
Concrete slab - 40 year old 9x9 asbestos vinyl tile on top of slab. ...
I have a similar situation. I discovered 9x9 vinyl tiles when I ripped out the carpet in one of my rooms. I'd like to encapsulate, put in some type of moisture retardant, then glue engineered wood planks. In my other rooms, the carpet & padding sit on top of the slab, so I was going to apply "Titebond 531" Epoxy moisture retardant on the concrete, and then glue the planks on top of it (the name of the glue I got escapes me at the moment). Could I do the same? Will the moisture retardant bond w/ vinyl tiles? Will it encapsulate the asbestos? Is there a better product to use?
Thanks.
jbk is offline   Reply With Quote
Old 03-22-2009, 07:19 AM   #14
Get out of the box!
Thanks.
No glue will survive the application over the 9x9 tiles,the cutback will find a away to reactivate, the resulting VEs will cause the glue to release.
I have seen projects like this fail on a massive scale.
I would suggest a non plastic underlayment like Quiet Walk be placed over it and laminate or floating wood like this http://www.indianafloorsllc.com/hand...dhardwood.aspx
be installed over it.
The other alternative is a product called Konecto unless you are gonna lay tile then you could use Ditra.
Old 03-22-2009, 01:27 PM   #15
jbk
Oh no! We've already purchased the engineered hardwood! We had no idea we'd find the vinyl tiles! It sounds like our only option is to remove the vinyl tiles and the cutback!?!?!
More On This Topic
Asbestos is a group of naturally occurring minerals that have been used in industry because they are resistant to chemicals and heat. The two subgroups of asbestos are chrysotile fibers, which are curly or serpentine, and amphibole fibers, which are... Read More »
Hyperpigmentation is a skin condition characterized by patches of darker-colored skin. This condition is common, affects people of all ethnicities and is usually nothing to cause concern. However, the dark patches can be unsightly. Fortunately, they are... Read More »
High maintenance plants that require frequent watering put a strain on the environment and take up a lot of your time and attention. Select drought-resistant plants for your garden instead by choosing the best plants for your area that have low-water... Read More »
One technique that you can use is using a hormone, a B1 rooting hormone, which is a liquid that we've already have mixed in this bucket here. What you do is you'd actually take your root stock and put it in the hormone and you'd let that soak. Even a... Read More »
Causes of the Common Cold
Causes of the Common Cold by Expert Village
Hi! This is David Jackel on behalf of Expert Village and I'm here to talk to you about what causes a cold. There are many, many viruses that cause the symptoms that we call the common cold, which is why it's so hard to fight the cold. Because there are... Read More »
Assuming Asbestos Tile mcconnre Flooring 35 11-14-2008 02:56 PM
How to remove vinyl tile for asbestos sampling? RDS Remodeling 6 08-14-2008 07:24 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
vinyl siding over asbestos?? Buckeyes97 Remodeling 3 10-22-2007 10:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
