Embossing Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 09:47 AM   #1
embossing linoleum
Good day! I have a question about embossing over linoleum. I am going to install Adura vinyl tiles over our existing linoleum. The old lino is in quite good shape and cut out any issues and filled with mapei quick patch. The old lino also has a bit of a pattern and have been told I need to emboss the lino. I was told I can use the mapei quick patch as a a skim coat. I tried this and found it to be very grainy, not a smooth finish at all - the lino has a smoother finish. I mixed it (powder to liquid) 3-1 diluted using both water and additive and applied it with a finishing trowl. Am I going about this all wrong? What should be end result look like? What should the consistancy of the product be for skim coating?
Any help is greatly appreciated to this newbie!
Terrilynn is offline   Reply With Quote
Old 04-16-2013, 11:15 AM   #2
Never mind, they sold me the wrong product. Should be planipatch not quickpatch. Thank goodness scraped off what I had already done.
Seeking advice for repairing small tear in bathroom linoleum floor lonlonmilklover Flooring 3 01-10-2013 03:08 PM
Water leak under linoleum? MarieW Plumbing 4 08-15-2012 08:02 AM
Linoleum not flush against tub bottom? shub Flooring 5 05-31-2011 11:59 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 08:11 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
