Old 10-11-2011, 10:49 AM   #1
electric radiant heat under marble
The marble is left over from a previous failed DIY project, and I've decided electric radiant heat would be the best heat for his room. I am redoing an enclosed porch off the master into a mini-nursery, then eventually sun room/green house. It is over an unheated root cellar, so I am wondering about insulating the sub-floor. Are there insulating backer boards? would some 1" foam board hold up between the sub-floor and backer board?
forresth is offline   Reply With Quote
Old 10-11-2011, 09:32 PM   #2
Super Moderator
Your safest bet is to insulate it from below---in the root cellar.
Foam board under the backer board is not a safe installation--
That is an expensive installation with heat mat---failure is not an option here.
Bud Cline (10-11-2011)
Old 10-12-2011, 02:25 PM   #3
I thought they used that stuff under concrete slabs?
Old 10-13-2011, 06:14 AM   #4
Super Moderator
Yes they do----and under a slab is fine---If the backer board was 4 inches thick that might work
Backer board is pretty flexible----
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Tiling over mosaic (1954) with electric radiant heat? ControlTech Flooring 2 02-04-2010 09:01 PM
Underfloor radiant electric heat dangdang Electrical 9 09-26-2009 12:49 PM
Electric Radiant heat on Concrete hayduke.klr07 Electrical 10 11-24-2008 08:31 PM
