Electric Mat, Ditra Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 07:44 PM   #1
electric mat, ditra floor
Hey all,
I've just finished deck mudding a 35 sq ft bathroom floor. I just want to confirm that the steps I have planned next are not a mistake:
1- felt (done)
2- galvanized lath nailed down 6" field, 4" edges (done)
3- Mud 1", 1 portland: 5 sand (done)
4- electric mat placed
5- level over with modified thinset (let dry)
6- apply modified thinset with v-notched trowel, place ditra (let dry)
7- apply/fill ditra with unmodified thinset, then apply more with notched trowel for setting of tile.
Did I miss something or do something wrong?
Also, why is it recommended that unmodified go between ditra and tile?
Thanks in advance!
zantar is offline   Reply With Quote
Old 08-21-2010, 09:52 AM   #2
UNmodified thinset does not need air to harden, and there won't be much between the membrane and a large ceramic tile.
DSGoose is offline   Reply With Quote
Old 08-22-2010, 12:23 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You are installing Ditra over another cementitious product. Generally the guidelines call for Unmodified under Ditra when going over a cementitious substrate. Modified should be for setting it to wood only.
poppameth is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
My Hardwood Floor Refinishing project roxksears General DIY Discussions 3 11-13-2009 06:43 PM
Radiant electric floor heat chatroom3542 Flooring 4 10-25-2009 09:31 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
