Electric Heated Floors Products Recommendations? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-05-2008, 01:16 PM   #1
I am thinking of installing an electric heated floor system when I re-tile my upstairs bathroom. Any recommedations of companies to use/stay away from? (I read on another message board about a bad experience wtih Thermosoft.) Recommendations on mats versus wires you layout yourself? Thanks.
Ted Uy is offline   Reply With Quote
Old 12-05-2008, 02:11 PM   #2
Floorwizard's Avatar
NuHeat has a great product.
Floorwizard is offline   Reply With Quote
Old 12-05-2008, 08:08 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Mats are generally easier for a DIYer. The loose cable has the advantage if you your layout is all cut up though. You can put it exactly where you need it.
poppameth is offline   Reply With Quote
Old 12-05-2008, 08:35 PM   #4
Check out Laticrete's Floor Warming:
http://laticrete.com/Homeowners/Prod...1/Default.aspx
RSandlin is offline   Reply With Quote
Old 12-06-2008, 09:13 AM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by Ted Uy View Post
(I read on another message board about a bad experience wtih Thermosoft.) .
I got my stuff from Thermosoft. No problems whatsoever.
The product was easy to install ( it was my first time laying tile AND putting in floor heating) and it works great. I did a pretty big kitchen, and got the biggest mat you could run on 110v. it is really sweet, i will be doing my master bath with heated floors as well
Mr Chips is offline   Reply With Quote
Old 12-06-2008, 10:35 AM   #6
Get out of the box!
Rewards Points: 260
Warm Tiles makes a good one we use to carry it but our supplier dropped it.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 12-06-2008, 12:09 PM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep, Warm Tiles is what we used on our last job. Seemed to be a good product and was cheaper than any of the competition I priced. Warmly Yours has to be the most expensive I've seen by far.
Old 01-17-2009, 11:01 PM   #8
Thumbs down
I cannot recommend Warmly Yours. It worked for a year. That's it. An electrician told us the thermostat wires were undersized. I notified the company who had in fact replaced the therm with a bigger one. They said it was out of warranty. We still have a nonfunctioning floor. The electrician couldn't fix it.
colden is offline   Reply With Quote
Old 01-22-2009, 07:31 PM   #9
I used Suntouch - Watts Radiant, going on 4 years now without a problem. I used the wire instead of the pre-made matts
For the same price I bought enough wire to do the bathroom, hallway outside the bathroom, & a couple runs down the long hallway
Old 01-25-2009, 03:43 PM   #10
Home Theater Guy
Warm Tiles from Easy Heat.
http://www.easyheat.com/Content1/Pro.../wt_detail.htm
Only problem is that i installed it only in the 1st floor bathroom when we gutted it a couple of years ago, and my wife keeps complaining that the tiles are cold in our 2nd fl. Master Bath!
Greg C is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Heated Floors Affecting Grout question Ted Uy Flooring 12 08-29-2009 01:45 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
