Edge Sander Technique - Flooring - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 06:56 PM   #1
Rewards Points: 150
edge sander technique
what is the proper technique when using the two hand edge sander when refinishing hardwood?
drewhart is offline   Reply With Quote
Old 11-06-2008, 08:06 PM   #2
The key is not to push hard. It can cause uneven surfaces which will show. Just let it rest on the floor and keep it from moving around too much. Above all don't let it get away from you. It can make some serious groves in a very short time.
If the area isn't bad and you are just cleaning up the parts that a floor sander missed I would use a vibrating rotary sander. It might take longer but it had less potential.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-06-2008, 09:20 PM   #3
Rewards Points: 150
should i move it around in circular motion, or in a straight line just along the baseboard. should i go back and forth, or just over each area once.
Old 11-06-2008, 09:51 PM   #4
With a belt sander you can't stay in one place too long. It will remove a lot of wood real fast.
Go over it as much as needed.
I have oak floors and they are very hard. It takes a lot to get any wood off those so I had to do a lot of standing.
In the past I have sanded CVG fir and even some redwood floors. Redwood is very soft and you don't want to be doing a lot of sanding on those.
Old 11-06-2008, 10:00 PM   #5
Rewards Points: 150
it's not a belt sander. its a circular disk sander.
Old 11-06-2008, 10:10 PM   #6
My bad. I somewhere read belt sander.
I prefer circular sanders.
But the same rules apply. Just go over it enough to do the job. No more.
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 09:28 PM
Edge Flooringwhat the heck? sammythebull Flooring 29 03-28-2008 10:57 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 09:44 PM
