-   -   Dura Ceramic Flooring (http://www.diychatroom.com/f5/dura-ceramic-flooring-28529/)
Gramea 10-15-2005 11:55 PM
We are looking into putting new flooring in our kitchen and laundry room. We saw the new Dura ceramic congoleum at a Home Show and really thought it looked good. My husband is very skeptical. I liked it because it was less messy to install, warmer, quieter and would not add a lot of height to the floor. What can anyone tell me about this product?
Thanks.
Elaine
MgMopar 10-16-2005 12:02 PM
The Dura Ceramic appears to be a resilaint/vinyle floor. This type of flooring is good for many applications. I personally use another ceramic look alike in my kitchen last time. I used a laminate product. I am happy with mine. No, it is not true ceramic but I have the look I was going for. I would believe this to be the case with the Dura Ceramic. It most likely wont be a 20 year floor or anything. It will not hold up the same as a true ceramic. But it should have a good life and I would assume the cost would be cheaper and much quicker and easier to install. So, It should perform well and install well from what I have read. If you truly like the look and realizing styles change anyway and willing to put new floor in when it shows wear. Go for it. You won't have cracked and lifting tiles that can occur with the ceramic or quarry tiles.:eek:
I understand why he is skeptical.:( I understand your "...less messy to install, warmer, quieter and would not add a lot of height to the floor";) I hope I helped. Maybe another forum user will be able to add more. Hopefully someone has used the product and can give there testimonial. :)
manoloK 10-07-2006 06:27 AM
Home decoration is not only about expensive and ornate furniture or about having crystal showpieces strewn around the place. It extends to basics like getting the fixtures right, the painting job well done and an attractive flooring that feels warm to the feet. And when it comes to the flooring aspect, it seems that there?s no looking beyond Dura Ceramic tiles, going by the glowing Dura Ceramic tile reviews.
Ceramic tiles have existed for many years and their popularity hasn?t decreased even a bit. They are highly regarded for their toughness and come in a variety of styles and colors. Thus you can obtain ceramic tiles to complement any d?cor whatsoever, from the rich Victorian style to the plain and simple. The good-looking ceramic tiles make for easy installation and the glazed variety, in particular, are easy to clean and maintain.
However, you need not go through the Dura Ceramic tile to realize that these tiles are above others. The Dura Ceramic tile reviews aren?t overstating even a bit when they say that the tiles have brought in the Gen Y of ceramic tile technology. Coming in an array of diverse looks, Congoleum DuraCeramic tiles are long lasting and easy to maintain.
Dura Ceramic tile are about the curious blend of ceramic and vinyl tile properties. The limestone composite base of the tiles give it a durability and robustness while like the vinyl tiles, the Dura Ceramic tiles are soft and warm to feel. Thus on the other hand with their soft touch they are ideal for spaces like the bathroom and the kitchen, while their sturdiness makes them viable for commercial areas attracting medium traffic and for domestic applications.
Dura Ceramic tile stress on the longevity factor of the tiles and also point out to the fact that they can withstand chipping and cracking to a large extent. Thus you can have the tiles safely installed in your kitchen without having to worry about walking on them softly or if you drop an occasional pot or pan.
With the Dura Ceramic tiles, you also get a Lifelong Limited Warranty against fade, stain and wear out. So walking on the tiles won?t mean that you have to walk on your tiptoes all the time.
The Dura Ceramic tile reviews are easy to wipe so that the occasional spill of the cola can be easily cleaned with soap and water.
The installation procedure of the Dura Ceramic tiles is easy and can be attempted on your own, which means on those rare occasions when you need to replace a tile, you won?t have to run around looking for a professional tile setter.
You also have the option of installing these ceramic tiles with or without grout. While with the grout, you will get the traditional look, the edge-to-edge look is more modern and will gel well with your sleek, contemporary wrought iron designs.
Dura Ceramic tile reviews are tempting and once you use the tiles, they are addictive.
